Stainless Steel Bolts, Take 2.. Group Buy?
    This thread... http://www.xs11.com/forum/showthread.php?t=37304 ... discussed what was needed for a 'carb set' and possible costs. Well, I did some research and I'll throw this out there for comment...
    There's a eBay seller who has both the carb kits and engine kits for about $16 and $40 respectively, including shipping. He is making money.... His kits do offer 'tumble polished' bolts; a bit shinier surface than a 'basic' bolt, but not what I'd call polished. After checking costs at McMaster-Carr, it looks like actual costs are about $5 for the carb kits and $16 for the engine kits. This is pricing the hardware out per each. The fly in the ointment is the quantities these are sold in don't quite match what you need. For example, to replace all the 6mm external cover screws on the motor you need 26 @ 35mm long, 26 @ 25mm long, and 14 @ 20mm long, a total of 66 bolts, plus two flathead screws for the clutch cover. Now, the 20mm and 25mm lengths are no problem as the minimum quantity is more than you need. But the 35mm comes in multiple of 25, so you're one short or 24 over... But even so, if you buy the minimum (50 35mm, 50 25mm, and 25 20mm), you're still saving a few bucks.
    If there's enough interest, I might do a large enough 'buy' to assemble some kits. Actual kit costs will depend on how many are wanted and how many 'leftovers' I have to eat. I probably won't include the two flat head screws for the clutch cover as I'd have to buy 50 of those, so unless there's enough demand (20+ kits), it will cheaper for you to buy those locally or reuse what you have. Same goes for carb kits; while there's a bit better 'break' in terms of how many are needed and how many you need to buy, I still have to eat the leftovers.
    If you want to get your own, here's what you need for the engine...
    26 - 6mm x 35mm. 20 for the cam cover, 3 each for the alternator and clutch covers.
    26 - 6mm x 25mm. Ignition/shifter/clutch/alternator covers, brake lever pinch bolt.
    14 - 6mm x 20mm. Bearing cover (in front of the starter), cam chain tensioner, intake boots, shifter pinch bolt.
    The carbs...
    '78-79 with cast tops: 8 - 6mm x 14mm (carb rail), 32 - 5mm x 15mm (tops and bowls).
    '80-82 with steel tops: 8 - 6mm x 14mm (lower rail), 24 - 5mm x 10 mm (tops and upper rail), 16 - 5mm x 15mm (bowls).
    A couple last things... First, be sure to use antiseize on any stainless fastener; these will seize at the drop of a hat and break off. Second, stainless isn't as strong as plain steel; maximum torque on the 6mm is 6.4 ft-lbs or 77 in-lbs. The factory spec is 7.2 ft-lbs on all the cover bolts, use the lower number, it'll be fine. If you decide to replace some of the other bolts, do check torque specs. The 8mm stainless is only good for 15.6 ft-lbs.
    I'm going to order some stuff from McMaster-Carr soon, so if there's interest don't wait....
  • WSL91
    • Feb 2012
    • 427
    • Quad Cities, IL
    Still looking for the screw size for the carb rails. I have the Yamaha # written down and was going to go to the dealer and get one and measure.
    98503-06014-00
    I'll be ordering screws for my carbs and covers. I already ordered an assortment and have most of the cover screws replaced so I'm just filling in. The carb kit I bought had 1 set for stamped and 1 set for steel covers in it and 1 set of bowl screws and as luck would have it that's what I own. What I need is a second set of bowl screws and 2 sets of rail screws.
    1970? Honda Z50... gone
    1974? Yamaha 100 Enduro... gone
    1974 Honda CB200... gone
    1981 Yamaha Virago 750... gone
    1993 Honda Shadow 1100... gone
    2008 Honda VTX 1800F
    1982 Yamaha XJ1100J w/850 final, Raptor ACCT
    1979 Yamaha XS1100SF "Chewey" Raptor ACCT
    http://www.johnsoldiron.com
    • XS11UFO
      • May 2012
      • 74
      • Palatka, Fla.
      The carbs...
      don't wait....
      I think Steve covered it.
      BTW For those considering it, I did my carbs local sourced and it ended up more than twice as much. Not an optional thing if you have gotten those J type Phillips screws out - you don't want to put them back in! IMHO
      Scott
      Scott
      1978 R100S BMW
      • WSL91
        • Feb 2012
        • 427
        • Quad Cities, IL
        Scott
        Guess I wasn't reading
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Steve, Im interested in the full monte. Any idea what you would cost would come out to be or will it depend on the amount of interest?
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
            It will depend on the amount of interest/how many sets I make up. Basic 'cost' will be about $20 for a full set, engine and carbs not including shipping from McMaster-Carr (typically about $10 per order). So if I make up five sets and buy enough to do that, my out-of-pocket expense will be about $130. Divide that by five and you get $26 per set. Add $5 for shipping in the US, and you're looking at $31 per set. Much cheaper than the eBay guy, and way cheaper than buying them per piece; I just paid almost $12 for just the cam cover bolts locally...
            Of course, I get to keep the 'leftovers' for free, but I should get something out of this....
            Looking at the numbers, if there's quite a bit of demand I may be able to get the price down another few $, if some don't want the carbs that may move the price slightly too; the carbs account for about $5 of the total.
            • Aches n Pains
              • 349
              • Reston, Va.
              Steve,
              Very interested in the engine set. I have the McMaster Carr stuff for the carbs but would do another set if it helped.
              Doug
              1995 KZ100P
              Pods, jets, pipes, cam adjuster, oil cooler
              1977 Ironhead - custom build
              Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
              Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                Look at the rest of the bike. There are lots of other spots that could use SS Allen caps and see if that makes the numbers work better.
                • JerseyJon
                  • Feb 2012
                  • 180
                  • Teaneck, NJ
                  Hi Steve,
                  You can count me in for the full set. Thanks again for doing this.
                  Jon
                  Hill? What hill? I didn't see any hill! Why wasn't there a sign? And where are my keys?
                  80sg
                  mods to come
                    I did do that, but there's enough differences between models that a 'standard' kit isn't practical. And the bolt sizes used for the motor don't fit most other places...
                    I've got five people who say they want sets so far, I'll watch this another few days to see if there's more interested before ordering. And after I see just how many want a set, I'll firm up the price and the contents. The carb hardware is a small problem; if I include a 'all carbs' set (enough to do either the late or early carbs), that adds a few $ to the total cost and the buyers will end up with some leftovers, if I 'specialize' the kit that reduces costs. In any case, I don't see any big swing in price, the $31 price should be within a few bucks either way.
                    For those who are interested, send me a PM letting me know if you want a full engine/carb kit, which carbs you have (early or late), or if you want just the engine hardware. I may end up including the carb hardware anyway to make it easier, but that will depend on the numbers...
                    • DAVINCI
                      • Jan 2011
                      • 1048
                      • Cedar Mountain, NC
                      BTDT, only bolt I couldn't get in stainless was the 110-120mm(?) bolt at the middle gear case so I got some stainless rod and threaded it. Used an acorn nut on the exterior. JAT
                        Yeah, I've been looking for that one. It's 180mm long (!), I found it at Fastenal at one time for $10 each but should have got it... NLA. I have found another vendor who has them, but minimum is 100, I haven't called for price...
                        • GTXS1100
                          • Jun 2010
                          • 224
                          • Columbia MO
                          Bolt kits
                          I would be interested it the whole bolt kit. Have been meaning to do my carbs for 2 years, and still cuss it every spring. Would you be using pay pal? PM me if you get the kits together plz.
                          80 XS1100G Black Betty (Daily Driver)
                          79 XS1100SF (Buddys Project)
                          82 XJ750 Maxim (Fathers Bike)
                          81 CB750F SS (Buddys Project)
                          06 GSX600F Sold! (Was Mine)
                          81 XS1100 Failed Bobber Project (Mine)
                          81 XS1100 Parts (Mine)
                          Grip it, Rip it, and Stick it!!!
                            Yeah, I guess I am only seeing 5 that would work. 2 on brake bar clamp 1 on the clutch perch and then the 2 grounds for the battery and the engine. I don't know what size the specials use for the lower triple tree fork clamps but the standards are larger than anything on the engine.
                            If you are doing it I would take a engine and carb kit.
                              Ok, an update. Right now it looks like I have 9 takers for kits. As it is right now, that puts the kit costs at $25 for just an engine kit, $31 for the engine/'78-79 carbs, and $32 for the engine/'80-82 carbs (more hardware on the late carbs). This includes shipping in the US by priority mail. If you pay with a USPS money order, take $2 off each price; sorry, but PayPal's 8% charge is too much to ignore.
                              I can sell just carb kits, but due to shipping costs being the same, you're looking at $12 (early carbs) and $13 (late carbs) per kit, or about the same as the eBay guy (although I will include the rail hardware, which he doesn't).
                              Due to the $200+ out-of-pocket costs to me, I will ask for payment before I order the hardware... retired guy on a fixed income y'know... I'll send a PM to everyone before ordering.
