Oil cooler install help...
  • Filter
  • Oil cooler install help...
    so im installing an oil cooler, i got the adapter plate installed, but when i installed the filter housing, i cant tighten the filter bolt anymore, but it seems the filter housing is not quite snug to the adapter plate...i used the spring and a washer ( washer to protect the rubber on the filter ) under the filter, should i not use that?
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
  • #2
    You need that washer so leave it there.
    • #3
      Is it a genuine Yamaha adapter plate or an aftermarket one?
      ^ This is what the Yamaha adapter and bolt look like.
      Check your reassembly against this diagram to make sure you haven't got anything in the wrong order.
      Should be no problems using the spring and washer under the filter
      • #4
        Ah, I was wondering if there was an extra adaptor bolt or not.
        • #5
          i believe its aftermarket...i got a lockhart kit from a member on this site and it came with everything...it appears that i got everything in the right order...the adapter plate with oring, then the adapter plate bolt with washer, the the filter housing with filter, then washer then spring, then filter housing and bolt....
          Wolf
          Moto Militia MC
          • #6
            Also just make sure that the filter isn't being pulled completely to the bottom of the housing by the filter bolt. I had an aftermarket filter that had a smaller than usual inner rubber seal. As it tightened up the bolt, the filter sqeezed down on it till it couldn't be tightened anymore, making the whole housing want to turn, which it couldn't. If that's what's happening, unscrew the filter from the bolt till it's sitting just above flush with the top of the housing, then wind the housing (complete with bolt) up till it hits the stops on the cases, then do the filter bolt up with your spanner.
            That's if that is the problem, mate. If not, I'm afraid I'm out of answers.
            Being a Lockhart unit, there may be other issues to have to deal with which other owners will be able to sort you out with.
            • #7
              Does the oil cooler interfere with the center stand or anything?
              Thanks,
              Doug
              1995 KZ100P
              Pods, jets, pipes, cam adjuster, oil cooler
              1977 Ironhead - custom build
              Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
              Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
              • #8
                Thanks,
                Doug
                Nope, it is no where near the center stand.
