Carb kits
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Carb kits
    I just received 4 carb kits from Georgefix. K+L kit K-620 or 18-2555. Not sure which is the right number. On the sticker it states XS1100E 1978.
    Anyway, I see the holes in the jets are not quite the same size. They are also not the same numbers. Old pilot jet says 180, new one is 210. Old main jet is 140, new one is 137.5. Old pilot jet is 42.5, new one is 45.
    I know these have been taken apart before as the butterfly screws were not peened.
    So the question is, do I replace all the jets with the new stuff or do I stick with the old? I don't have any major modifications on the bike. THe exhaust is not factory but its nothing special either.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    Use the installed jets, which I assume are genuine Mikuni. I also wouldn't use the kit needles. Just the float valves/seats, gaskets, and idle screw/spring.
    • Tat2demon
      • Jun 2012
      • 718
      Damn, that seems like a big waste of money if you buy the whole kit.
      Thanks
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        For a 78, 210 air jet, 45 pilots, 137.5 mains. Those are stock numbers if they are Micuni parts. If you have after market pipes, the previous owner likely attempted to compensate for those.
        • Tat2demon
          • Jun 2012
          • 718
          Those are the sizes that came with the kit.
          So we have one that says use the old ones and one that says the new ones are the right size. Any more input?
          These carbs are used from a different bike so I have no idea why these different jets were put in.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
            • 3193
            Are your carbs from an early or later XS? That is simply the most important question to ask. After we know that it becomes much simpler to help.
              Skids was not saying to use the jets in the kit. He was just saying the the numbers on the jets were correct for a '78. He also that they are correct if they are genuine mikuni.
                I'll note that you can find both 210 and 180 air jets in the '78 carbs. If you have 180s installed, I wouldn't change them.
                As to the 'waste of money' thing, even without using all the kit parts his kits are usually still cheaper than buying just the 'needed' parts separately. The idle screws generally need replacing along with their springs, and just the idle screws can cost up to $8 each. Georgefix's kits is the one of the better values for these bikes IMHO...
                • Tat2demon
                  • Jun 2012
                  • 718
                  From what I can tell from the ID post, they are from a 78/79.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
                  • Tat2demon
                    • Jun 2012
                    • 718
                    Ah good. Didnt like just tossing all the other parts thinking they were half the money..
                    Nate
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
