79 Yamaha xs1100 Special suddenly won't start
  • Nynatv
    • Jul 2012
    • 3
    I ran my xs1100 for 120 miles yesterday. It ran sharp and excellent all day then all of the sudden, it started to pop, skip, lose power.. Sounded like it was only running on 3 cylinders for about 3 miles then died completely.
    Turns over but will not fire. Has fuel.
    Any thoughts?
    79 SF
    What is the condition of the battery? Quitting on you the way it did makes me think your battery gave up the ghost.
    • Nynatv
      • Jul 2012
      • 3
      Good battery voltage. It turns over when I try to start it but will not fire
      79 SF
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        Okay, it turns over. Next step, Do you have spark? Pull the plugs and ground them to the head and then crank. Spark on all 4?
        Also check to see if the plugs are wet/dry/sooty, etc.
        No spark, check the pick up coil wires. (left side cover)
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          What is the condition of your fuse box? Is the IGN fuse in tight? Did you test the battery, or assume it's OK because it cranks the starter?
          It wasn't raining while you were riding, was it?
            Any thoughts?
            Hi Darrin,
            did you get it home before it quit or is it still parked someplace?
            Easiest thing to do first is pull the plugs and check for sparks.
            If you see all 4 with nice fat blue sparks as you crank, it's fuel.
            If you don't it ain't.
            Has fuel, you say, but where? Unless it's actually being sucked into the engine the fuel does no good.
            Check the octo, switch to "prime" and check fuel into carbs, then the big one,
            pull the carbs and clean them.
            • GLoweVA
              • Jun 2011
              • 1957
              For the 79 Special: the main fuse (30 ) is on the left side of the fuse panel and continuing from left to right are the headlight fuse (10 ), turn signal fuse (20 ), and ignition fuse (10 ).
              Looking at the wiring diagram, it looks like the ignition fuse feeds the starter solenoid thru the right handlebar 'kill' switch, so If it's cranking, then that fuse should be good.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
              • jwhughes3
                • 2798
                • Home of the Alamo
                pickup wires
                Sounds suspiciously like broken pickup coil wires.
                Intermittent as random connections are made until it goes out completely.
                Under left timing cover, check each wire by gently tugging on insulation - every 1/2 inch or so - should be firm - if you find a spot that pulls apart easily then its broken inside there.
                When mine went out it would run (badly) at about 45mph on the 2 cylinders I could get power to until I fixed it.
                John
                '81 XS1100H - "Enterprise"
                  • 5073
                  On 2 of my standards, at about 60 mph or so, I get a fuel delivery problem that is instantly rectified by switching my left petcock to PRIME. I suspect that there is an issue with vacuum pressure to operate the petcocks to where two of the cylinders start dropping out. I really should couple the output fuel lines together and then branch them out to the carb T's. Long story short, try switching over to prime if it happens again (both sides) just to see what happens.
                  • xs11lover
                    • 1433
                    • Montoursville Pa
                    Did the vacume line pop off the carbs?
                    79 XS11 Special (Lazarus)
                    79 DT 100
                    • mjpxs11sh
                      • Jan 2011
                      • 299
                      • N/E, Illinois
                      your description sounds exactly like when u run out of gas and have to flip the petcocks to reserve. not getting fuel into the combustion chamber? fuel, air, spark, and compression is simply what it needs. easy to check them all to see whats missing. good luck.
                      Max
                      81 XS1100SH Black Beast Mutt
                      Kerker 4/1
                      stock carbs and air box.
                      78 headlite, handle bars,
                      1 set of ea-160/85mph guages,
                      crash bars, cruise control
                      Other 2 Wheelers
                      78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                      94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                        If you try to run a special on a low tank, it will do what you describe. Check to make sure the petcocks were on the RUN position, and NOT PRIME. 120 miles you should be on reserve if you are getting good mileage!
