Yes I am very suspicious of the 1-4 coil because the plugs on cyls 1 and 4 are sooty after I do a run where I make it start cutting out. I think the timing advancer moves pretty freely, I played with it alot while checking the wires. Also I have done some runs with the vacuum advance disabled. Problem still occurs, just a little higher in RPM.
My stator and field coil measure good, but my charging output is a little low at 2k RPM (13 ish). But I've had a few XS11's and they were all like that. Only way to improve that may be to replace all connectors in charging system, swapping regulators didn't help.
So am leaning toward 1-4 coil. I noticed this issue is vaguely heat related (maybe). First run not quite as pronounced as following runs.
Getting tired of riding around full throttle without my seat on, battery acid is hard on the a$$, plus you have to sit forward all the way so you don't sit on the ECU. : D I've heard of "butt dialing" but not "butt igniting"
Whoda thunk?
