Carbtune results at different RPM
  • KA1J
    • 664
    • Groton, CT
    Trying to decide what RPM to use the carbtune at; If I have the engine at 1100 RPM and balance them level it changes as I increase RPMs. If I set them level at 1100 RPM they become asymmetric till 3K or so and then are level.
    If I set them level at 2K RPM where it's closer to where I'm usually riding at in average around town traffic, they are way off when back down at idle.
    However, If I set them level at 2K, they stay level up to the upper RPMs
    Seems like I should set them at 2K, closer to where the bike is running when in operation, the only time the bike is at 1100 RPM is when I'm not moving and I don't keep it there for long with the engine running.
    Thoughts on this?
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    I'm assuming that those rpms you checked at are all with the bike stationary. (ie. not on the road and definitely not under load)
    Under load (bike going down the road), the whole thing is completely different.
    (more suction, throttle open more, thus more fuel flow, etc.)
    I kinda do agree that you'd want the butterflies/carbs to be sync'd in the normal operating band (ie 2-3krpm while riding), but however, actually dialing these in may be difficult if not impossible.
    Any other ideas from the super gurus?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
      The carbtune should only be used at or below normal idle speed. It is not designed to be used to adjust anything at speeds higher than that. Also, since you have an XJ, you'll need the YICS eliminator tool to get a real reading from it.
      • KA1J
        • 664
        • Groton, CT
        Thanks!
        I have the YICS eliminator in 24/7 so that's covered.
