Torque
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    Torque
    It may have been stated here and I missed it but many times I see post of new members needing information on torque values for various bolts etc.
    There are different types of torque wrenches and there are issues which can cause severe problems if used or maintained improperly. There are fixed beam and barrel and some different varriations. This link will give you some helpfull information that can prevent you from overtorque of bolts.
    The one important thing I wanted to bring up is never leave the barrel type wrench loaded( loaded is set at a value other than 0). Leaving the wrench set with a value over a period of time has been known to knock the callibration off in these wrenchs.
    You also have to be careful when ever you add any adaptor inbetween the wrench and the bolt you torque.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
    Originally posted by ViperRon
    ...The one important thing I wanted to bring up is never leave the barrel type wrench loaded( loaded is set at a value other than 0). Leaving the wrench set with a value over a period of time has been known to knock the calibration off in these wrenchs...
    That needs a bit of clarifying...
    DON'T turn the wrench to 'zero'; what Ron means is set it to the lowest value it can measure i.e. if the wrench's range is 10 to 80 ft-lbs, set it at 10, 50 to 250 range, use 50, etc. Most of the 'click' design torque wrenches will be ruined if you 'unload' them too far.
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Thanks Steve haven't had one that does not go to 0 for so long had forgotten. Just trying to help many really do not know they need them unloaded.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
