Have you tried to make a run without those cheap filters on.. just open carbs? That's the very first thing I would have tried to rule out. If it does the same thing with them off, then that's an easy check off the list. What you describe is the exact same thing I had a problem with when I tried them.
Oh... and you need to have the left timing cover off and the bike running to check those pickup coil wires. Do a little tugging on those wires and see if it dies or stumbles.
