Fixed crankshaft seal but it still leaks
  • a3dudek
    • Apr 2012
    • 31
    • Eagle, Colo.
    Basically what the title says. Any suggestions?
    Right side or left? Sure it isn't coming from the oil galley plug in there?
    • James England
      • 3039
      • North of England
      Mmmm... not fixed then!
      Did you distort or damage the seal when putting it in? They have to be tapped in by the outer ring, equally (I use a socket spanner). Is the spring facing inwards, as it should? Is there a possibility that the spring was missing (I always check before fitting) or somehow popped out when fitting?
      When fitting an oil seal, I try whenever possible to use a small piece of ultra-fine emery paper, dry, and I wrap it round the shaft and give one turn only. It can remove glazed deposits off teh shaft (from the old seal edge). Did you check the condition of the crankshaft end to see that it was smooth? Also, importantly, did you lubricate the inner leip of your new seal with oil before fitting?
      If no to any of the above, I'd be tempted to remove the seal and start again. They're cheap, aren't they?
        If the crank bearings are bad and letting the crank move around, new seals won't help... but do as Nate (And James) says. My statement is a worst-case scenario. If you've got the crank exposed, or the rotor on the right side, you can grab it and try to move it up or down, or side to side. If you feel movement, that's the problem. Could have also been damaged on installation? Did you put any gasket sealant on the outside edge of the seal before you tapped it in?
        • James England
          • 3039
          • North of England
          A certain amount of 'end float' is acceptable though.... that's if you push on the end of the crankshaft, as opposed to lifting it. As Trbig says though, any slack up and down isn't right.
          BTW... are you positive that you used the correct seal? If all else fails, perhaps you could use a seal with a smaller inner diameter? As small an increase as possible.....
            James is correct.. by "Push and pull" I meant front to back. Sorry. Side to side, (Left to right) there will be some movement.
            • sparks
              • May 2012
              • 89
              • Grants Pass, Oregon
              For that type of seal I always used an installer which was a lip that fits the part of the seal you smack to install and a round hub that fits inside to spread the seal lips and help retain the spring.. I have a kit that has many different sized lips and hubs that screw onto a shaft that you strike with a mallet..
              Hope that's as clear as mud.. you can get these at any parts house (mine was a snap on but you dont have to spend that kind of money). Saves a lot of grief when installing seals.
              Lee
              (Sparks)
              79 SF
              • James England
                • 3039
                • North of England
                Lee
                (Sparks)
                So, assuming the tool worked as it should, and the seal is undamaged, with the spring inside.... it could be
                1. Incorrect seal size. Buy correct size
                2. Leak from outer part of the seal...perhaps a small amount of damage when removing the old seal. Put silicone round it when you install
                3. Damage to crank end. Not likely but there could be some baked-on gunge where the oil seal touches it.
                4. Not a leak from the seal. Could be gallery plug. Or even the crankcase itself. I would clean the whole area with solvent. Dry it well and then puff a fine dusting of talcum powder on the casing, near the seal and also the gallery plug. This will show where the oil is weeping/leaking from because you'll see a trail through the talc.
                • a3dudek
                  • Apr 2012
                  • 31
                  • Eagle, Colo.
                  so it is the left side seal. i installed 32x48x8. it for isn't the oil galley plug because i can see the oil coming from the ignition cover weeping hole.
                  i am 99 % sure i put the seal in correctly because it took a couple times (i wasted one seal), i used a perfect size PVC pipe to gently tap it in. .
                  there was some play in the shaft (left to right) but not up and down when i changed it (at least what i remember.)
                  i oiled the seal before i put it in and the spring was in the proper spot on install.
                  i also used a small amount of gasket sealant on install, should i have globbed it in cracks. i might have damaged the outer part of the case where the seal fits.
                  the leak was decreased down to a drop or two a day when i replaced the seal (much better than it was) but it has been very hot where i live this past week and have noticed more consistent dripping. i also put about 400 miles on the bike last week (the most miles since i got it up and running)
                  thanks for all the comments guys, keep the suggestions coming please
                  • James England
                    • 3039
                    • North of England
                    That amounts to the same thing. Up/down and left/right but I doubt there was any play...it's easy to 'remember' incorrect things when stripping bits off. Double-check it though.
                    I strongly suspect that the crankcase(s) have minor scratches from whatever tool you used to get the old seal out. Even one scratch would be enough and would account for the increase in hot weather when the oil is thinner and able to get through.
                    I think you should buy another seal. Take the one out that you've just put in. Clean the inside surfaces of the crankcases right the way round, using clutch cleaner on a lint-free cloth... it won't take much. Check for scratches and gouges and verify how far in you can put the seal (since it has no external lip like the OEM one).
                    If the groove in the crankcases where the OEM seal located are empty of OEM seal bits, I would run my finger round them with a blob of sealant in order to block the groove up. Then put the new seal in with a good amount of sealer...RTV or similar.
                      Did you check for a groove on the crank where the seal sits? Sometimes dirt grinding in the same spot for years will cut a groove into the metal. Also, did you buy a single or double lipped seal? I've had MUCH better luck with the double lipped seals since they obviously aren't going to ride on the same spot that the old one was. If you can't find a double lipped seal, then maybe try a 32x48 x7
                      • a3dudek
                        • Apr 2012
                        • 31
                        • Eagle, Colo.
                        i bought a double lip seal
                        • cowboy1157
                          • Jul 2011
                          • 14
                          • Summerville, GA
                          Did you use a speedy seal along with the timiken seal it takes both to seal up properly on the crank shaft. I found this out the hard way.
                          • a3dudek
                            • Apr 2012
                            • 31
                            • Eagle, Colo.
                            what is a speedy seal?
                              • 9980
                              Speedi-sleeve Most auto parts houses carry them. You'll have to know your exact shaft diameter though.
