Turn signals not latching on
  • JustAddHP
    • Sep 2011
    • 3
    • Detroit, MI.
    I have a problem where my turn signals do not latch on. If I hold the signal switch over, they work fine and flash. As soon as I let the switch go, they turn off. This is the same with either direction. Any ideas?
    This is on a 1981 XS1100 Standard.
    B-Shock
    There is no replacement for displacement!
    1981 XS1100H with Windjammer and bags
    1979 xs1100SF - Future project
    2008 Harley Nightrain
    Non Motorcycle toys
    1999 F-150 Lightning
    2008 G.T. 500 Convertible
    1989 Banshee - big bore and alcohol and and and
    If your signals haven't been altered (OEM flasher, canceller in place, etc), try unplugging the canceller. If that fixes it, the canceller may be bad. If that doesn't, you've got issues in the switch, likely broken wires.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Steve, doesn't the switch have two tabs on either side that can get bent a little too far and not make contact, thus when the switch goes back to middle/neutral then the light would turn off?
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        If those get bent it either causes the turn signals to never cancel or to not turn on at all because they are in contact all the time (never cancel) or never contacted (never turn on). His symptom does sound like it may be the auto cancel unit canceling as soon as the turn signal on signal is released, that is unless the switch has something wrong and the switch is not latching into either the right or left position and is flipping back to center inside as if it were being pushed in as soon as the lever is released.
        • JustAddHP
          • Sep 2011
          • 3
          • Detroit, MI.
          Thank you very much guys! It was indeed the cancelling module. Luckily there was one on a spare harness I had purchased to cut up for connectors. I had tried replacing the wrong module at first. There is a 4 pin mocule just to the left of the air snorkel I had tried replacing first. Then of course I figured out that it was the module next to it with the small 6 pin connector with 5 wires. I still am not quite sure what the 4 pin module is. :P
          Thanks again!
          B
          B-Shock
          Non Motorcycle toys
          • jayel
            • Apr 2012
            • 152
            • Birmingham, Iowa
            Thanks again!
            B
            most likely the headlight relay, headlight doesn't come on until engine starts ... black, white, blue/black, and red/yellow wires
            where are we going, and why are we in this hand basket?
            Iowa the Beautiful Land 1980 XS1100SG
