Stranger than Fiction
    Steppenwolf came over last weekend and we were looking over my bike to figure out why the rear wheel is rubbing the swingarm. He noticed that a larger portion of the axle protrudes through the swingarm (the larger chrome part, that pulls up against the torque plate) than on his bike. I also have the complete swingarm, brake and wheel assembly form the wrecked bike. With it fully assembled, it looked like the same gap as on his bike.
    So we took both my spare assembly and the one on the bike apart. Measured all the components and compared. Nothing of any significance was different. I measured from the lip of the FD to the lip of the hole in the swingarm the axle goes through. Found the one on the bike had a larger dimension. WTF, a bent swingarm!!??
    Today I went through the process of swapping out the swingarms. Getting it all assembled, and find I now have the same problem again. I do notice that in order to get the large part of the axle through the swingarm, I have to pull hard to get it lined up. So I took it all back apart and looked and thought. Took the shock off the swingarm on the right side to make sure it was not causing any force. No change.
    Now I got the idea to pull everything out of the way, brake assy, torque plate and just slide the axle through the swingarm and the FD. Same issue, not lining up well.
    So, now I am pondering, is the frame bent and therefore causing an issue with swingarm when I torque the swingarm bolts into place? Does not seem likely, but still a possibility. Or os the FD itself some how fubared to the point it is not lined up? I guess my next step is to swpa the FD from the wrecked bike onto this one and see what lines up different.
    You might look at this thread..... http://www.xs11.com/forum/showthread.php?t=37211
    I have found swingarms that don't quite line up right, although it does sound like your problem may be the FD. Or you might have a 'tolerance stack' issue with your particular parts...
      Well, I found the problem, and it was in the GD Clymers manual. Swingarm pivot bolt torque is listed at 47 FT-LBS in the Clymers, I looked it up in the FSM and its 43-52 IN-LBS. I thought it was ALOT of torque on those bolts, and it was, enough to actually torque the swingarm out of alignment!!
      I am at the point of burning that book I think!!!
      Recommendation for a new Sticky - Misprints in the CLymers manual!!
        Make sure you didn't damage the swingarm bearings; does it still pivot smoothly?
          Feels fine to me Steve. I was concerned about the bearings. I just could not believe it distorted the swingarm itself??!!
          • James England
            • 3039
            • North of England
            There's been a thread about precisely this before.It was that Clymers again!
            • DAVINCI
              • Jan 2011
              • 1048
              • Cedar Mountain, NC
              It's also wrong in my '78-'79 FSM, listed at 72 ft-lbs. It was meant to be the pivot bolt locknut setting but the entry just reads pivot bolt. That was a bad day for sure.
