Okay, I'm an 80 owner, so I don't know about the differences in the 81.
I'm trying to help Nightengale out on his 81 project and his XJ carbs.
So, He's got an 81, so it has the different TCI and no mechanical advance and the 'mech advance' is programmed into the TCI.
And right now, he doesn't have his vac advance hooked up.
So currently with out a timing light, I'm not sure when he's firing. I think it might be slightly retarded (like 5deg or so, but again no way to verify).
Some of the symptoms are: ocasional to frequent backfiring out the exhaust and out the carbs.
He has no mufflers on right now.
I provided a suction to the vac advance (don't ask me how
) and his idle went up nicely (a little high) but smooth with little to no back firing.
We also tried putting his mufflers on to see if back pressure helped.
I'm just trying to figure out where to go from here.
We're thinking of riging up some kind of temp vac source. (like a turkey baster)
This will 'advance' the timing so that he won't back fire much if at all.
He could have a lean condition too, so we might back out the idle mix screws a turn or 2.
I'm going to have a look under the timing cover and see what's what.
I guess maybe I'm getting ahead of myself. Maybe we've got to fix his charging problem before we can dial in the engine. It's just a PITA trying to troubleshoot the electricals with the bike running when it's acting so erratically.
Anyone with any ideas? (Setup: 81H with XJ carbs & Pods, no vac advance port (yet) and no mufflers)(guy who set up the carbs says they're ready for pods and straight pipes.)
