Oil Type?
  • alaskaxj11
    • May 2012
    • 11
    • Anchorage, AK
    Oil Type?
    The guys at the local Yamaha Shop suggested Yamalube Perfomance Semi-Synthetic SAE 10W-50. Took it for a ride tonight and the clutch is slipping. This bike has been garaged since 1998. Any suggestions as to the right oil type? Is this Semi-Syn Okay?
    1982 XJ 1100 J
    1977 XS 750
    1974 Jeep J20 (401, Turbo 400)
    Unless you're riding in temps below 59 degrees, that's too thin. Switch to 20W-50...
    • James England
      • 3039
      • North of England
      I only ever use 100% mineral oil in the XS1100. I would not ever use semi or full synthetic. I'd say it's almost 100% why your clutch is slipping. 20/50 mineral oil is best, I've found.
      • tonyg-5386
        • Aug 2010
        • 25
        Shell Rotella 15w-40 in my 79. No problems at all.
        • neJeff
          • Jun 2011
          • 346
          • Nebraska
          Thats a +1 on the Rotella. I use it in all my bikes and it's inexpensive. Synthetic is not good for old motors. New motors or rebuilt I would say yes to synthetic
          Current Daily Rides / Projects
          1979 Yamaha XS1100F (since 2015)...Project
          1980 Suzuki GS850G (since 2012)
          1979 Kawasaki KZ400B (since 2013)
            Originally posted by neJeff
            ... Synthetic is not good for old motors. New motors or rebuilt I would say yes to synthetic
            It's not that the synthetic oil is bad for old motors... it's just as good for them as new or rebuilt motors. The problem is the clutch friction plates designed for oil that was around 30+ years ago. So, I would see no problem running synthetic in a bike with a rebuilt clutch using modern friction discs... although I've heard a lot of tales about motors developing leaks with synthetic that they never had before?
              • 9980
              I used to use Rotella in other bikes too but it makes the 1100s clutch slip.
              It's the clutch friction discs that don't like synthetic. As a matter of fact you could run just about anything you wanted except for the clutch problems.
                Probably had nothing to do with the oil, but I used to use Rotella exclusively. The first motor I ran it in spun a crank bearing on the way to a rally. I rebuilt the motor and put new bearings and crank in, and that motor and bearings were toast after @ 2500 miles. Both issues were lube related, so I switched. Many have used it with no problems, so I'm just throwing this out there for a "Use at your own risk" type thing. I never had any clutch slippage issues with it though.
                • neJeff
                  • Jun 2011
                  • 346
                  • Nebraska
                  This is what I was referring too, the leaky aspect of the slippery synthetic in old motors
                    • 9980
                    That is a trait of synthetic in any engine. If there is ANY place it can possibly leak synth will find it.
                    • ddragon63
                      • Jan 2012
                      • 1101
                      • Ridgefield, WA
                      well I'll just step in here and blow all your minds... I have run Castrol ACT-EVO XTRA-4T in my XS many times. and it is a partial synthetic... Never had a problem with it, other than finding it in my local shop in 20w-50. Lately it seem to be like a needle in a haystack to find in that weight. All the V-twin guys have really jumped on it and eat it up faster than my lazy a$$ can get to it. So this last oil change I ended up with old school Castrol 4T as autozone stocks the crap out of it. The ACT-EVO is great oil. I've ran it in most every bike I've owned. 10w-40 in my rockets and dirt bikes, 20w-50 in Old Man and Izzy...
                      the only thing synthetic in a part synthetic oil is the additive pack. the base is still petro. As for the leaking anyone thats ever put anything synthetic in an old small block chevy will tell ya, it will find all the holes and exploit them REAL quick.
                      The slipping may be from too thin of oil... also make sure they gave you oil designed for a wet clutch. The only creature I know that runs that wide of a viscosity gap is BMW cars... they like the german 10w-50 and 10w-60 oils. YMMV just some food for thought....
                      I hate oil threads... they draw me in like a car wreck
                      Don
                      old:
                      1989 kawi ex500
                      1996 yzf-r6
                      1999 yzf-r1
                      2001 kawi zx-6r
                      2000 Ducati 748
                      2002 YZF-R1
                      2005 V-Star 1100 Classic
                        Hey Steve,
                        Check out his location ....Anchorage Alaska, I think 59 degrees is their HIGH!
                        Others have already provided the answer he needs, hopefully he can get regular dino juice up there in the greater white north. But he may want to run the 10-40 or 10-50 if he can get it...if they make that range??
                        The other thing for him(AlasakXj) needs to watch out for is the friction reducing statement on the SAE/API seal...you don't want to use any oil with that. But even after getting the right oil, the clutch may still slip....the OEM
                        springs wear out, and folks usually end up replacing theirs with good HeavyDuty type springs..Barnetts are recommended highly!
                          • 9980
                          The v-twins, Harley particularly, has a separate wet clutch from the oil run in the engine. Engine oil is completely separate from the clutch oil so you can run 2 different types.
                          Don't know about others.
                          • WSL91
                            • Feb 2012
                            • 427
                            • Quad Cities, IL
                            Nothing more fun than an oil thread
                            1970? Honda Z50... gone
                            1974? Yamaha 100 Enduro... gone
                            1974 Honda CB200... gone
                            1981 Yamaha Virago 750... gone
                            1993 Honda Shadow 1100... gone
                            2008 Honda VTX 1800F
                            1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                            1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                            http://www.johnsoldiron.com
                            • ddragon63
                              • Jan 2012
                              • 1101
                              • Ridgefield, WA
                              +1... I'm personally not a fan of diesel oil in my motorcycle... they are WAY opposite engine designs. Sure diesel oil still has all the good stuff in it to protect like zinc and phos. but its designed for a low speed high work motor... not a high speed low work motor. I may be wrong but I'm sure Rotella doesn't have anti-foaming agents in it as its designed home moves @ 3800 max rpm and isn't being aerated by a constant mess gear box. Each to there own. Not gonna tell a Fella how to care for his bike or what to use. just trying to make a point.
                              I've heard alot of "oil is oil" conversation... its not. They may all start in the same crude vat, but the ad-packs are way different from one specification to the next. Just saying
                              Don
                              old:
                              1989 kawi ex500
                              1996 yzf-r6
                              1999 yzf-r1
                              2001 kawi zx-6r
                              2000 Ducati 748
                              2002 YZF-R1
