It's been a ling time since incubus gave me any problems. It was a bulletproof ride for three years. But I got a new job at the end of last year and my riding and wrenching time were reduced to almost zero. My bike was out once this year, in January, for a 120-mile round trip. Ran fine then, but the idle was crummy. It sat for about three months before that ride and has sat since.
So this weekend I decide to fix it. I pulled the carbs yesterday and cleaned the main and slow jets (all the slow jets were were clogged) and cleaned out the enricher circuit tunnel on the bowls. Then I got ready for a ride.
Well now the idle is real crummy. I checked the pipes and one and two were cool. Easy, I figured. That's clearly a fuel issue. So I checked the petcock. I got flow when I put vacuum on it when in "on," and also flow on prime. Then I checked the fuel line routing, then replaced the fuel line and fuel filter (mounted vertically). No dice. The fuel filter did not seem to be filling up, so I pulled the drain plug from carb no. 1. There was fuel in the bowl. I put the petcock on prime and fuel flowed easily from the drain hole on the carb.
So what can restrict fuel flow is the line and petcock seem to be OK? Anything in the carbs or messed with with you mount the carb is fair game. What can I try to narrow down the search parameters? I could easily have messed something up, but I am at a loss right now what that could be.
For what it is worth, the plugs on 1 and 2 appear fine and I got good spark when I checked them. I get good puffs from the plug holes when I turn them over, so it does not seem to be a sudden catastrophic loss of compression.
Thanks, y'all.
Patrick
Thanks, y'all.
Patrick
