Speedometer drive dog
  • Bartman
    • May 2012
    • 200
    • Jefferson, Georgia
    I just replaced the bearings in the front hub. Before I put the speedometer drive dog in I have a question. Mine is cupped or concaved enough to almost hit the bearing. Should I flatten this drive dog?
    79 XS11
    Hey Bart,
    From what I can see of the microfiche, it appears to be FLAT, so if it's gotten curved, then you may need to gently flatten it. I've not taken mine apart, so I can't speak from personal experience with this part, just know that the tangs can get bent when the drive gets installed wrong! Hopefully someone will chime in with more definitive info!
      • 8962
      The inner ring with the drive tabs (left in photo) is flat, the outer ring (center in photo) has a recess to fit down towards the inner drive ring. The rubber seal (right in photo) keeps everything held in place.
      • WSL91
        • Feb 2012
        • 427
        • Quad Cities, IL
        Hey Bart,
        Thats exactly what was wrong with mine. Tangs bent out and piece bent in towards the bearing to the point where it would not drive the speedo at all. Took it apart and straitened everything up and works like a champ. Just make sure to line up the recess in the speedo drive as you re-assemble the front axle assy.
        1970? Honda Z50... gone
        1974 Honda CB200... gone
        2008 Honda VTX 1800F
        http://www.johnsoldiron.com
