Surging Idle = How to fix?
  • a3dudek
    • Apr 2012
    • 31
    • Eagle, Colo.
    My idle is surging, some times stalls out it is so low then other times it slowly climbs to 1,500-2,000 rpms.
    any suggestions on how to fix it?
    Sounds like a vacuum leak or the need to synch your carbs. To track the vacuum leak, try spraying some starter fluid around the intakes, or use unlit propane.
    • a3dudek
      • Apr 2012
      • 31
      • Eagle, Colo.
      yeah i was thinking a vacuum leak was possible. it idled fine before i took apart and cleaned the carbs.
      i'll look at it tonight though
