My rear valve stem has been leaking since I painted the rims. I took the lock nuts off to tape around the core and the seal broke and its been a slow leaker since
I've been dreading pulling the wheel tire back off. Don't want to dismount it as it has 40%-50% tread left and don't want to re-mount that on my Highway ridin bike. Finally decided that it's coming apart and the old tire goes to the XS which will probably never leave town and a new one goes on here. Ordered up a set of Shinkos so if I changed my mind they would go on the XS as it needs tires anyway and with 2 tires (front and back) had free shipping.
Then it hit me, what if I could break the bead on the bike without pulling the wheel? Tire can stay, I don't have to run to my storage unit and get my tire bead breaker and wheel balancer, don't have to dismount the tire, etc. Etc.
It took a couple bites with a c-clamp and a wood block moving along the tire. Placed the bike in gear to help. I blocked 1 side so that it would only come off on one side. This turned out to be a 30 minute job, not 2+ hours. Found a bunch of aluminum corrosion under the stem. The rim cleaned up just fine and I installed a new stem which it probably needed anyway.
Looks like the XS gets the matching set of Shinkos
