I have a leaking float that i put some quicksteel on but havent put gas in the carbs yet. I figure it will just disolve even though it says impervious to chemicals on it. I was wondering if the float would work with one pontoon. I think i am going to order the plastice ones so they will all be new but was wondering if i could run one pontoon until i get the others. It seems to me that it would still do the same thing. Anyone ever try it instead of buying a new float or to ride until it got there? My local cycle shops here in WV dont carry anything for our bikes and they want $46 for a float.
carb float
Won't work with only half. The plasic floats require some modification in the older carbs or they will stick.I have a leaking float that i put some quicksteel on but havent put gas in the carbs yet. I figure it will just disolve even though it says impervious to chemicals on it. I was wondering if the float would work with one pontoon. I think i am going to order the plastice ones so they will all be new but was wondering if i could run one pontoon until i get the others. It seems to me that it would still do the same thing. Anyone ever try it instead of buying a new float or to ride until it got there? My local cycle shops here in WV dont carry anything for our bikes and they want $46 for a float.
IMHO stick with what it came with.Greg
Solder it
If its brass, solder it. Just dont get crazy and weigh it down.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
i tried soldering an old lawn mower one first and i cant solder worth crap. Couldnt even get any solder on it. Cleaned it, sanded it and still couldnt get it.Jeff
77 XS750 2D completely stock
79 SF XS1100 "Picky" stock with harley mufflersComment
did you use flux with the solder? That cleans any inpurities.FOXS-XS11SG
1980 XS11SG-sold
1999 Vulcan classic-sold
1982 XJ 650-sold
Old is only a state of mind......JohnComment
it should work,copper is generally easy to solder.It must be very clean thoughFOXS-XS11SG
1980 XS11SG-sold
1982 XJ 650-sold
The problem with soldering sealed containers like that is that the air inside heats up and then you get an air stream rushing out of the hole and that keeps the solder from covering the hole.
When I soldered mine I put the whole float into a glass of cold water and just had the small area to be soldered sticking up out of the water. Clean the area well and then coat it with flux and heat and dab the solder on.Nathan
Theodore RooseveltComment
+1 on what Motoman said,I have heard that one before Nate,but never tryed it.FOXS-XS11SG
1980 XS11SG-sold
1982 XJ 650-sold
New brass floats are $17.50 each....
☮Comment
Thanks phil those same ones are $20 on ebay with same picture. Well, i got lucky though, a guy who lives about a mile from me has a 79 like mine that has been sitting outside forever and his dad has a MNS. They have tons of carb parts so now i have a good float and just put it in. Gonna ride to work tommorow, yeehaw. Another thing, if i knew it was so easy to fix a leaky petcock, i would have done it the first day i owned the bike, its fixed now. So, i had a leaky petcock and a bad float on the same side so i lost almost a whole tank of gas out the airbox and in the crankcase. All of thats fixed now and fresh fluids. Thanks guys.Jeff
Ageed
+1 on what Nate says . . . I found out the hard way when one fell apart on me as I tried to solder a pin-hole leak!1979 F
Mac 4-2 Exhaust
T-Kat Fork Brace
Spade Fuse Box Mod
Stainless Steel Braided Brake Lines
140.0 Main Jets
45.0 Pilot Jets
266 X-2 Needle JetsComment
I used to make and repair jewelry and an old trick to join/repair broken rings without removing the stone is to bury the ring in fine sand, jewel facing down with the affected area sticking up. The sand becomes a heat sink & dissipates the heat and the stone does not crack. If you do this with your float, I suspect you will be happy with how you can now solder without grief.
It's an old jewelers trick and it works.82 XJ1100 Maxim "hurricane"- DEKA EXT18L AGM battery , NGK BPR6EIX spark plugs, Green Dyna coils, Sylvania SilverStar Ultra H4 bulb, 139 dB Stebel Nautilus air horn, Home-made K&N air filter based on an original paper filter frame, new piston rings, Barnett Clutch Springs, SS braid/Teflon brake lines, TKAT fork brace, rebuilt calipers, master cylinders, new brakes, reupholstered seat, lotsa little things and so many answered questions here.Comment
