I'm removing the Kerker from my 79 and installing a set of XJ Headers and some aftermarket mufflers. I think this will be a decent looking setup. Anyway I ran into a problem which I'm sure someone else has before. The XJ Exhaust flanges bottom out before the pipes tighten up. There is about 23/32 distance between the pipe end and the flange on the Kerker and 11/16 on the XJ. While just over 1/16th difference its enough that the XJ flanges bottom out.
So I see at least 3 options.
1. Add something between the motor port and gasket
2. Add something behind the flange on the pipe before the cast exhaust flange
3. remove 1/16" off the cast flange.
Option 3 is doable but would be hard to get a real even cut with a hand held grinder. There is a recess cut in that sets on the pipe flange so it doesn't have to be perfect.
Option 2 seems like maybe a wrap of clothes hanger wire under the cast flange might do the trick.
There are hard plastic spacers/gaskets in the exhaust ports now, I have on my desk 4 new Yamaha 4be-14613 gaskets which may be a tad thinner than the hard plastic ones that are in the exh ports now.
Any ideas?
Thanks
Any ideas?
Thanks
I've nicknamed the bike Chewy in honor of its previous mechanic Chewbacca. Every time I fiddle with the bike I find something else "farmerized" as we refer to it in the antique tractor world. I should post a picture of how they attached the engine guards!
