newer style wheels or spokes
  • MR.D
    • May 2012
    • 40
    • jasper, GA.
    i have been thinking of ditching the mags for something else anyone have instead of the mags and help would be good.
    78 E
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Your not going to find much... you can find spoke wheel for the front but the rear is another story because of the shaft drive... we have had discussions on here about it, just the search tool it might turn something up.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      There was one guy down in Australia I think that re-machine the center hub of this rear wheel so that it would accept spokes and then he laced it up. A lot of time and money but it is one of a kind!
      There was also a VERY limited production Japan only bike that had a spokes wheel that would fit our bike. Don't remember the bike though.
      The problem Is the shaft drive. The hub is what makes it near impossible to do a rear spokes wheel.
        You could convert to the 'swirly' XJ mag wheels....
          Hi MR.D,
          as has been posted, XJ swirly mags will fit but they are still mags.
          A very rare set of wire wheels made for a bike only sold in Japan will fit but you can't find them or afford them if you could.
          XS650 wire wheel (3 styles available) will drop right in the front.
          Wire wheel at the back is doable but it ain't easy. Here's what you need to do:-
          Cut the hub out of a cast rear.
          Use a lathe to turn the spoke stubs & hub OD into a pleasing profile.
          Turn on 2 registers to accept spoke rings.
          Weld on 2 spoke rings you made from 3/16" thick aluminum plate.
          Lace the modified hub into the rim of your choice.
          • daveyg
            • Feb 2009
            • 411
            • Boise, ID
            Be careful, if u put a lace wheel in front and keep the mag in back people might start mistaking it for a 4cyl Harley.
            BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
            80 XS1100SG(cafe in progress *slowly)
              No way, Davey!
              It'd need to be a wire front and DISC rear to trigger that particular misapprehension.
              Wire front and 7-spoke cast rear sez the rider is keeping his bike on the road while the rear wheel is still in the shop.
              FYI, it's simple wrench work to swap wire & cast wheels on an XS650. I swapped my XS650's cast wheels for wire wheels some years back because it improved the bike's aesthetics.
              I swapped back because it takes cast wheels to run tubeless tires and I got sick of cleaning the wire wheels.
              The wire wheels are now on my son's XS650, he likes to clean things.
              • Mathh
                • Nov 2006
                • 699
                • Beek, Netherlands
                You mean the very first Japan only XS750 called the GX750
                MV Agusta Brutale 910R '06.
                Yamaha MT-09 Tracer '15 grey.
                  That one has a 18" rear wheel; IIRC Yamaha built a 'special', limited edition model (850?) that had a 16" rear wheel, but seems to me that they only built 200 of that one...
                    All one really needs is the hub. Outer diameter can be whatever you want.
                    • Eveready1100
                      • 539
                      ^ Here's a pic of Jonesey's XS as he built it.
                      ^ Here's a pic of Jonesey's XS now in Chrisso's hands
                      ^ here's a pic of the 750 Special with wire wheels (Japan only)
                      Haven't heard anywhere that they actually built and sold this bike in any numbers.
                      ^ Plus another shot of the GX750 (Japan only)
                      Dunno about the difference in rim size though, Steve. By measuring the photos, they both appear to be the same size.
                      ^ Gratitious pic of spoke wheel
                      • MR.D
                        • May 2012
                        • 40
                        • jasper, GA.
                        thanks everyone! was just dreaming of something diff right now i need to get her running first.
                        78 E
                        • James England
                          • 3039
                          • North of England
                          Nice as they look, spokes wheels are a pain, IMO. They take a LOT of cleaning to keep them looking good and, even then, all sorts of muck gets into the sides of the spokes where they join the hub. Also, the raised bumpy bits in the rim where the spokes go through take some polishing.
                          I had spoked wheels on my 1975 Goldwing GL1000. I must say, I wouldn't feel easy whacking the power of an XS1100 through a spoked wheel... especiallyy one designed and made at home, as it were.....
