Wrong oil = slipping clutch = How To Clean The Clutch Plates ???
  • a3dudek
    • Apr 2012
    • 31
    • Eagle, Colo.
    so pretty much the title of the of the post. how do i clean the clutch plates after i put the wrong oil in the bike and it is causing the clutch to slip under a lot of load.
    Thanks
    Change your oil and ride the bike.... It might take a bit of riding, but if the clutch plates aren't damaged that should do it.
      Normally 2 or 3 good days of riding and it'll clear up.
      • a3dudek
        • Apr 2012
        • 31
        • Eagle, Colo.
        cool i was hoping it was that easy but i wasn't sure if i needed to do anything else
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Thought I would ask...
          What oil did you put in to cause clutch slip?
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
            • 6764
            more than likely you used an oil that said Energy Conserving on the round label on the back of the can...which is what you DO NOT WANT. They have friction modifiers... mainly Moly and will cause the clutch to slip...Make sure to get a non energy conserving non Moly oil.
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
            • a3dudek
              • Apr 2012
              • 31
              • Eagle, Colo.
              Exactly what i did, i used a oil that said "Energy Conserving"
              I didn't notice the slip until i put my girl friend on the back and tried to accelerate up a hill. never really noticed it without her on it except when i was WOT and shifted real hard.
              The oil i got doesn't specifically say its for motorcycles and wet clutches but it doesn't have the "Energy Conserving" label on it. i was wondering if there is a big difference between a generic oil and a motorcycle specific oil.
              Has anybody noticed a difference?
                I use el cheapo wal mart 20-50 oil.
                Go to this link and the picture right off the bat shows you what you are looking for, and not looking for.
                • OregonRider
                  • Jun 2010
                  • 33
                  I used Turco(?) T-1 blended motorcycle oil with MPZ friction reducer that's supposed to impregnate the surfaces. Another "modified" oil to not use. Clutch started slipping when I'd roll on the throttle at 4k on the tach. Just changed oil to the T-4 straight petroleum oil. I hope time and miles with the non-additive oil clears up the problem.
                  82' XJ1100 turned "bagger" with Vetter Fairing.
