Leaky shock
  • mack
    • 2411
    • Ontario, Canada
    Leaky shock
    Came back from a ride on the LH and after I parked I noticed a leak. Took me a long time to trace the origin. Seems my left rear shock is leaking and blowing back into the tire rim and spraying everything south of the mid drive shaft. I've taken shocks apart before but never down that far. Are leaks repairable or am I in the market now for a different set. If so anyone have a spare left shock? Also I assume that a sh shock is the same, just need to be painted?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    The factory units and 90% of aftermarket units are non-rebuildable.
      +1. Yep, if it's leaking, it's toast. The SH shock should be the same other than finish.
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        And etiquette states that it is good form to replace both shocks at the same time.
        Lets face it, they both have the same amount of wear, and one new one may have a different damping rate than the remaining old one, and the old one may spring a leak any day now.
        But, it is your bike. CZ
