Stupid Question Looking For Good Answer!
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Originally posted by ddragon63
    ... Insert spring and and bolt into body of Auto CCT... as you collapse the spring you will hear the Auto CCT ratchet outwards and make contact with the chain guide bar. Tighten Bolt with copper washer into the Auto CCT body. Roll motor over by hand to verify there is no binding in engine. Let RTV dry, Fire, Ride, and enjoy.
    The Auto CCT can be a little noisy... its not too bad, its just a different noise that you will have to get use to.
    Just a few things...
    1. You may not hear the CCT ratchet at all, make sure you turn the radio off if you want to hear it.
    2. Make sure you use the proper torque (its low, something like 10 ft-lbs, maybe less) when you put the large adjuster bolt back into the body.
    3. The motor will sound a little different but mine got quieter.
    Now enjoy the maintenance free chain adjustments.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      Originally posted by 79specialdude
      What is the hole in between exhaust 2 and 3 on the front of the engine? I noticed that it leaks oil.
      Then there is the simple solution, clean off the leaky tensioner and apply some RTV to stop the leak.
      • Elevener
        • 608
        • small town in TEXAS
        Originally posted by natemoen
        If you do not have the octy anymore and the petcocks run straight to the carbs, then no you can't just rub one because each petcock only feeds the 2 carbs that it is hooked up too. .
        Yeah, all petcocks get really jealous if you rub just one.
        Trapped in time. Surrounded by evil. Low on gas.
        1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
