#*@! Middle drive fill bolt
  • BobBaldy
    • Apr 2012
    • 43
    • Evansville IN
    I'm glad I read somewhere on this site to pull the fill screws before you drain the middle drive or rear. I've tried PB Blaster, a 1500 watt heat gun and a foot long box wrench on the end of a 6mm allen and nothing works. Before I buy some allen sockets for my impact gun I have one question. Is the fill screw a normal lefty loosey or am I going at it the wrong direction? I need to know before I attack it with an air tool.
    80 G, Spaghetti pipes, K&N in stock airbox, Galfer S/S lines.
    It has been my experience that folks who have no vices have very few virtues. -Abraham Lincoln
    http://80xselevenrebuild.blogspot.com/
  • jwhughes3
    • 2798
    • Home of the Alamo
    Yes regular thread
    Try these tips...
    John
    '81 XS1100H - "Enterprise"
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      It's a right hand thread, just has good Zen with the housing. Go get some allen sockets and put an impact on that thing. Make sure the allen is all the way to the bottom, stripping it will only make it more difficult.
      When you put the plug back in, put a plastic or aluminum crush washer under the plug. This will help you get it off in the future. Also, use the proper torque when putting it back on. They seem to self tighten due to the difference in material. Good luck!
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
        Buy a hex head plug and put the crush washer on it. Don't reuse that POS plug.
          If you don't mind the look of having a hex head bolt there, you can get them at Autozone in many shapes and sizes. Just put some anti-sieze on the threads next time, just like you put on the spark plugs.
          • jayel
            • Apr 2012
            • 152
            • Birmingham, Iowa
            which brings up the question of what size and pitch is the plug?
            where are we going, and why are we in this hand basket?
            Iowa the Beautiful Land 1980 XS1100SG
              IIRC, it's a 14mm. Same exact threads as a spark plug. Not sure of the pitch though.
                That's the correct size.......thinkin' the pitch is 1.25 but not sure. Ace or True Valu has the drain plugs that replace those POS alen plugs. They come in stainless. Easy way to get original out is take a sharp chisel and make a straight on notch in side of plug base. Then angle your chisel a bit in that cut and pop the chisel right smartly with a hammer. In the trays right next to the hex plugs are the sealing washers. They are a thick fiber material. Use one on the middle drive fill plug and two on the final drive fill plug. Two on the rear plug so the shoulder of it is above the recess in the casting........lefty loosy.....righty tighty......
                • BobBaldy
                  • Apr 2012
                  • 43
                  • Evansville IN
                  Thanks for all the moral support guys.
                  After another day soaking in PB Blaster I was able to get the plug out using name brand Vise Grips and a bit of luck. Of course I stripped the allen head part of it first before getting out the Vise Grips but it dosen't matter because I'm taking everyone's advise and putting a 6 point back on it.
                  Somthing I always do when replacing a bolt is to run a nut down both the old and new bolts to make sure the thread pitch is right. They almost always stock nuts for the bolts they sell, so that's an easy way to check before going to the register.
