So, here's part one:
I want to put this round speedo,
Into this square hole for my G.
First, I cut the lip off the edge from the white arrow on the bottom left to the right and then up to the right corner (the other white arrow) (This is the bottom and right side of the speedo and will be least visible after reinstallation.) I gently pried up the cut edges and I was able to slide the cover off to the upper left. (red arrow)
Here you can see the backside of the ‘cover plate’ and how little I took off with the dremel tool.
Here’s the cover plate removed. It’s held in with simple rubber gasket that was probably sticky with age.
Now to remove the guts, I removed the 2 mounting screws (red arrow) and loosen the rubber grommet for the trip knob (other red arrow)
Then I just wrangled the guts out of the housing.
Note that mine is really dirty/sooty due the gears in this one tearing itself apart.
I thought I had a spare SG speedo, but I forgot I gave that to Nightengale (John) for his project. So, I currently have nothing to try to put in there.
I'm watching a 650 (120mph) speedo on ebay.
Does anyone have one they'd like to donate to see if this mod is doable?
I saw that a member here had the guts for one, but it's already accounted for. (that would have been perfect)
So now I'm waiting for a round speedo guts so I can put it all together.
I had I little trouble getting the guts out because of the trip reset knob, so I had to notch it out.
My only question is how well is the trim ring attached?
