Looking for new gaskets for the stock exhaust slip joints. Anyone know if the ones that mikesxs sells work for the 11? Also is there a gasket at the crossover joint or just at the 2&3 head pipe to collector joint? I don't see one listed on the fiche but it also states that 3 of the gasket are needed.
Exhaust Slip Joints
Exhaust Slip Joints
Theodore RooseveltTags: None -
Yes, there is one at the crossover.Looking for new gaskets for the stock exhaust slip joints. Anyone know if the ones that mikesxs sells work for the 11? Also is there a gasket at the crossover joint or just at the 2&3 head pipe to collector joint? I don't see one listed on the fiche but it also states that 3 of the gasket are needed.
I had a Honda muffler that had the same diameter gasket in it, it was a little shorter than the Yamaha gasket, so you might see if you can find a real parts man at the local Honda shop, who would recognize it on sight. CZ -
Order 'em from Yammy Nate.......part #3JJ-14653-00..........that's the part number off one of my extras in the packaging.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Vintage Honda, Yamaha, Kawasaki & Suzuki motorcycle parts. Find carburetor kits, brake parts and seals by model and year. Free USA & Canada shipping over $50.
Muffler Joint Gasket
#17-4522 | Yamaha XS1100 (1978-1981) US$ 6.00
Fits: XS1100 (78-81)
Muffler Joint Gasket 38.5mm x 44.5mm x 25mm OEM Ref#1L9-14714-01, 33M-14755-00, 3JJ-14653-00 Fits: HeadPipe79SF
XJ11
78EComment
That part number I listed for u Nate IS for the #2,#3 head=pipe at the bottom and the cross-over connection. The only XS/XJ that would have a muffler gasket is the XJ. Not sure what SFerinTexas's point is.http://www.partsnmore.com/parts/yama...itting]=custom
Muffler Joint Gasket 38.5mm x 44.5mm x 25mm OEM Ref#1L9-14714-01, 33M-14755-00, 3JJ-14653-00 Fits: HeadPipe81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
The 2 part numbers are for the same thing. They cross reference each other. The fiche at boats.net gave me the 1l9.... number and then I searched for the # you gave me and it brought up results with both numbers. So they are the same thing.
Doesn't parts n more have some stupid minimum order $ amount?Nathan
Theodore RooseveltComment
