Anybody ever removed and then reattached the YICS emblems on the XJ engine covers? I want to polish the covers and redo the emblems but don't want to break anything in the process.
YICS emblem removal
Aren't they cast into the metal?1980 XS850SG - Sold
-H. Ford -
Nope, not cast into the covers....
Well, the cam cover but not the ignition/alternator covers...
I'm in the process of doing this. The emblems are stamped metal pieces and just glued on. Use a small screwdriver and carefully pry them off. I'm going to reattach mine with some automotive two-sided trim tape, you can get that from various places online or from your local body shop supplier.Fast, Cheap, Reliable... Pick any two
Huh! I always thought they were cast into the covers, making it impossible to remove them. I guess if you install the YICS Eliminator, you could also eliminate the badges on the outside too!
-H. FordComment
That's what I'm in the process of doing, no YICS and no more YICS emblems!
LarryInventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
See it here... http://www.youtube.com/watch?v=cBYT4C9_6AcComment
I was going to ditch mine too, but that leaves an indent where they were that looks funky. You might be able to smooth the cover enough to remove them, but you'd have take off quite a bit of metal....Fast, Cheap, Reliable... Pick any two
Can't you swap the 81 covers?1970? Honda Z50... gone
1974? Yamaha 100 Enduro... gone
1974 Honda CB200... gone
1981 Yamaha Virago 750... gone
1993 Honda Shadow 1100... gone
2008 Honda VTX 1800F
1982 Yamaha XJ1100J w/850 final, Raptor ACCT
1979 Yamaha XS1100SF "Chewey" Raptor ACCT
http://www.johnsoldiron.comComment
No, the YICS is on the XJ, and the covers don't interchange....Fast, Cheap, Reliable... Pick any two
That'll work............till it melts from the heat.........JAT to consider..........Nope, not cast into the covers....
I'm in the process of doing this. The emblems are stamped metal pieces and just glued on. Use a small screwdriver and carefully pry them off. I'm going to reattach mine with some automotive two-sided trim tape, you can get that from various places online or from your local body shop supplier.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
The covers on my bike are missing the emblems and the rectangular indentation where they belong looks a little kooky. My parts bike has covers with emblems so my plan is to polish and then swap them. I do have the YICS Eliminator to be installed...I guess after that YICS will stand for "Yup, I Can Smoke ya"
Billy
1982 XJ1100, Ceramic Coated Headers, Raptor ACCT, Barnett Clutch Springs, Dremmel Fix, TC's Fuse Block, De-Linked S/S Brake Lines, 850 Final Drive, Yahman's YICS Eliminator, Pods, stock jetsComment
They DO get that hot.......but hey, may just turn into really good glue. A super thin film of Gorilla glue.....I say really thin so it don't pooch out all over.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I agree. Hot enough to burn the skin. I feel the heat through my boots when I have my feet on the highway pegs. It reminds me to slide them out a little further!1980 XS850SG - Sold
-H. FordComment
I plan on filling it in with a piece of aluminum that I have cut to fit. Will probably use JB Weld to glue it in place.
82 XJ1100
64 Yamaha YA-6
77 Suzuki TS-185
Gawd! How some folks can fuss over trivia.
If a little empty indentation bothers you that much, take the covers to a bro with engraving machine who will cut something in those bare pockets.
You've already gone away from stock by eliminating the YICS so perhaps the Yamaha triple tuning fork or simply the initials XJ?Last edited by fredintoon; 05-11-2012, 09:20 AM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
