Greetings all,
Unfortuanately my electrical gremlin is still with me - the bike starts and runs great one time, and the next time - no spark! I put on a replacement harness, new battery and very time I check voltages, etc., everything appears to be normal. The only thing that may be malfunctioning is the resistor - is it supposed to drop voltage to the coils after starting? It doesn't - stays the same. It is both coils not firing, so whatever it is must be common to both. When it decides to run, it runs great.
When it is being a pain, the only time you get a spark is after to try to start it and then turn the handleber switch to off, and you get a spark. Once it backfired and sounded like a shotgun - had the neighbors running!
My next step is to basically rewire the ignition portion and eliminate all the unneeded stuff and see what happens!
Any thoughts appreciated - the guys in the funny coats are gaining on me fast!!
Regards
Keith
Regards
Keith
Folks can bypass the BR just for starting diagnostics....and If the bike starts and runs with it bypassed, but not in circuit, then they know the BR is bad and can replace it. But folks are not to run their bikes for very long with the BR bypassed because it will fry the coils at full 12 volts for very long!
