First real ride
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    First real ride
    So, i got my 1100 special legal today and took it for its first ride in a few years. The tach doesnt work and the speedo is a little slow to get to speed but is right when it gets there (i think). I love this bike, plenty of power. It still seems to not run right in lower rpms but it seems to be getting better the more i ride it. Now i guess i need to figure the electric tach out. Anyway, i love this bike, it makes my xs750 seem very slow. I wish it had another gear though.
    77 XS750 2D completely stock
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    I just went for another ride and got the nuts to open it up in 3rd and it seems to miss a little up at the top of the rpms too. I dont know how many rpms cause the tack dont work. Could this be because it hasnt been synched? I just eyeball bench synched it. It still runs very good though, good enough for me to ride everyday now. I'll say it again, i love bike.
      Very definitely! Sync that thing, and you'll be grinning from ear to ear!
      • jjz28
        • Apr 2012
        • 1023
        • Beckley, W. Va.
        Thanks bug, I need to try and find someone around here that knows how to do it, or buy the synch tool myself. By the way, i love your website!
          • 5062
          If the tach is not functional there is a good chance that it isn't charging. I would clean the connections in the wire clip behind the fuse panel.
          • Wouldstalk
            • Mar 2012
            • 37
            • Stockton, CA.
            Cheers mate!
            Give the carbs a good cleaning and then get them synced!
            Also check Float needle seal and give the jets/emulsion tubes a good soaking in carb cleaner.
            • jjz28
              • Apr 2012
              • 1023
              • Beckley, W. Va.
              I'm pretty sure its charging because the lights get brighter when reving like it is supposed to. I am still going to clean all the connections and try to get this thing working.
                As the saying goes, there's an APP for that, specifically, you actually have the fix for it right in your garage....your 750. Take a look at the forums in the mods, the 750 final drive conversion, you may decide to do the conversion, but you can always go back to OEM if you don't like it. Not sure if you're in the mountainous portion of W. Va.....or is it all mountainous? Folks have commented on how tall the first gear feels after the mod, and so you might like the lower gearing of the OEM for the twisties and such!?
                A miss could be a number of things, carbs, pick up coil wires, corroded spark plug wires/caps, etc.!! Get it running strong and right, and then you can better gauge whether you'll want that extra gear or not. These engines like to run and can handle 5-7 k rpm all day long, but you'll need your tach working to be able to tell where you are in the power band!
                • jjz28
                  • Apr 2012
                  • 1023
                  • Beckley, W. Va.
                  Hey topcat, Wv is pretty much all mountains. I will check into that 750 final drive, maybe i could switch them. I never even thought of the plug wire cause they are taped up. I need a new set for sure! Also, I think it needs synched, i just eyeball benched them halving the whole like i did on my 750, wich has never been synched yet but really needs it. I really need to get me a synch set.
