hey, i was wondering if anyone had used the lithium batteries? i hear its bad with the charging system, but haven't heard any concrete no on getting one. i contacted T99ford, but haven't heard back.
lithium battery
lithium battery
1979 xs special, just finished the top end rebuild and then i still have lots of work.
progress thus far...
http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
"If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -IncubusTags: None
Originally posted by Shockman54 View Posthey, i was wondering if anyone had used the lithium batteries? i hear its bad with the charging system, but haven't heard any concrete no on getting one. i contacted T99ford, but haven't heard back.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
i was going to put it under the seat.1979 xs special, just finished the top end rebuild and then i still have lots of work.
Originally posted by Shockman54 View Posti was going to put it under the seat.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Originally posted by Shockman54 View Posti was going to put it under the seat.Ahh, the simple answers...
Joab
"If nothing else, it will be interesting..."
______________________________________________
1979 XS1100SF
1972 XS2 650
Ozark, Alabama
Originally posted by Joab View PostAhh, the simple answers...
Lithium iron batteries (which is the type being talked about, NOT lithium ION) are much safer than lithium ION and are also MUCH lighter than even the sealed MC batteries, plus have very very low drain rates, something like a few percent in a year, and they do have one certified for our bikes, stating that our charging systems are stable enough for them. What with wanting max cranking amps AND saving weight where I can, I can see where they can be a good idea where I can save almost 10 lbs without actually getting rid of anything. Plus they actually increase available cranking amps as you crank rather and decreasing like lead/acid batteries do.Cy
Originally posted by cywelchjr View PostLithium iron batteries (which is the type being talked about, NOT lithium ION) are much safer than lithium ION and are also MUCH lighter than even the sealed MC batteries, plus have very very low drain rates, something like a few percent in a year, and they do have one certified for our bikes, stating that our charging systems are stable enough for them. What with wanting max cranking amps AND saving weight where I can, I can see where they can be a good idea where I can save almost 10 lbs without actually getting rid of anything. Plus they actually increase available cranking amps as you crank rather and decreasing like lead/acid batteries do.
Lead/acid batteries are very well tried and tested and have proved to be immensely reliable (hence still being the main type of battery for vehicles) and safe under charging. Weight reducing on an XS1100 is pretty futile since it weighs such a lot to start with. I doubt it would make any practical difference to fuel consumption, handling or anything, to reduce the weight of this bike by a few pounds. OK, maybe a few dollars a year.....
Given the newness of the lithium-iron/ion battery in motorcycle use, I personally would leave it for a few years until the technology is really proven in this particular application. I have an electric bicycle which uses a lithium-iron/ion battery. The charger is fan-cooled and goes through a specific charge cycle which takes about 3 hours. The battery gets hot when being charged. I really wouldn't want one in a motorcycle.Last edited by James England; 04-27-2012, 07:55 PM.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
i was getting a custom seat from kott motorcycles, and a lithium iron battery is small enough to fit underneath it, freeing up the space it normally goes for other storage ideas i had. whereas a lead acid one will not fit under the seat, so i was hoping to get creative there . the ten pounds don't bother me that much (like a different thread stated, the rider can lose weight easier than the bike in some cases) i hear what you are saying james, it just seemed that there were two sides to the debate on this site from other threads that i read. but i would much rather hear from the wonderful people on here than what the manufacturer claims on some infomercial or website. so the next question i would have, is there some way anyone can think of to break up the charging cycle? perhaps have some sort of timer to limit the time the bike will be charging the battery and somehow not ruin my charging system?
plus i doubt i will ever be riding this bike for more than 3-4 hours at a time anyway... would that matter?1979 xs special, just finished the top end rebuild and then i still have lots of work.
