My new tire is defective..correct?
  • mharrington
    • 407
    • Holland MI
    This is for the front of my XS650. I bought the tires online and installed the front today with my tire levers. It went on surprisingly easy (first time doing motorcycle tire) The tire is crooked- wavy. Is this a chord defect? I couldnt have damaged it- it went on OK.
    Wavy:
    White letters are to close to the rim edge- the bead is fully seated.
    I can return it within 60 days- 60 days will be wed the 25th!!
  • daveyg
    • Feb 2009
    • 411
    • Boise, ID
    Looks wacky. I wouldn't hesitate to send it back.
    BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
    80 XS1100SG(cafe in progress *slowly)
    • mharrington
      • 407
      • Holland MI
      Im probably gonna get screwed. I just spoke to a customer servcice lady and she faulted me for not seeing the defect before the tire was mounted. I told her most times you cant see problems until the tire is aired up. I bought the tires 2 months ago and they sat until I got them mounted a few days ago- then went to put them on today. I have to ship back on my dime to the MFGR for warranty. I hope I dont get slammed.
        You don't have the tire fully seated on the rim yet... you might think you do, but I can see that it's not.
        Look carefully around the rim/tire edge; there's a small 'line' molded into the tire that should be perfectly even all the way around if the tire is seated properly. That line disappears by the lettering....
          +1 I saw that first thing too.
          • mharrington
            • 407
            • Holland MI
            I noticed it too and aired it up to 40psi and beat on it with a rubber mallet- removed the valve stem and beat on it some more- really lubed up that area with dish soap- stood on the tire wall....re inflated to no avail. No matter what I did I could not get that defect out. Visually the tire was up tight against the rim edge- Should I let a shop mount it and see what happens?
            • James England
              • 3039
              • North of England
              You need to put at least 60psi in to get that tyre to mount correctly. As has been commented, it is quite obviously not seated properly. Put washing up liquid along the difficult bit when the tyre is deflated. Then inflate, hold the wheel opposite the bit where the line disappears. Face the incorrectly seated bit downwards. The, holding the wheel at either side, bang the wheel against a hard surface (eg road) and kind of pull towards you when it hits the road. Do this several times, taking care that you don't angle the wheel so steeply that the rim can hit the road.
              Doing the above, along with lots of pressure, usually 'pulls' the incorrectly seated area out of the rim where it's stuck. You'll find that several of these bangs accomplishes it. Just make sure you grab the wheel and don't let go when the tyre hits.
              It works on tires too
              • jayel
                • Apr 2012
                • 152
                • Birmingham, Iowa
                agreed but don't go over the 60 lbs. also leaving the tire set overnight at pressure will allow the bead to slowly work it's way out
                where are we going, and why are we in this hand basket?
                Iowa the Beautiful Land 1980 XS1100SG
                  40 PSI won't be enough.... start adding more in 5 lb increments until it seats. Do lube the bead, that makes a big difference. These can be very stubborn, more so than car tires....
                    • 3193
                    Try reducing the tire pressure to about 10 or less pounds. Then bounce the tire on the floor to get it to the right position to seat. If the line Crazysteve is talking about is not even around the tire keep doing it untill it is. I would not ride to the end of my driveway with a tire that looked like that.
                      I recommend you remove the valve to totally deflate the tire and break the bead on at least that side of the rim. LEAVE the valve OUT and inflate until it "bangs" into place (or60psi). You need compressed air to achive the shock value it requires.
                      If this sounds like a "do over" that is because it is
                      • WSL91
                        • Feb 2012
                        • 427
                        • Quad Cities, IL
                        Valve core maybe?
                        1970? Honda Z50... gone
                        1974? Yamaha 100 Enduro... gone
                        1974 Honda CB200... gone
                        1981 Yamaha Virago 750... gone
                        1993 Honda Shadow 1100... gone
                        2008 Honda VTX 1800F
                        1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                        1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                        http://www.johnsoldiron.com
                          Originally posted by WSL91
                          Valve core maybe?
                          Yes. The part of the valve that goes in the Valve Stem so you have a 10mm hole to blow air in a big rush.
                            Hey there Harrington,
                            As everyone has stated, the bead is NOT seated. This was explained and shown in the front tire replacement tech tip! Just did this with a big rear tire, lubed it up, filled it to ~15 psi, and then bounced it against the garage floor until the bead worked it's way out to the edge, then was able to inflate to full pressure, nice and smooth. Just like Michael Jackson said.......
                            'bead it, bead it"!
                            • b.walker5
                              • Feb 2009
                              • 1745
                              • Invercargill, New Zealand
                              Aint a Defect... as everybody else has said, it aint seated properly.
