the never ending flow of questions....
  • Shockman54
    • Feb 2012
    • 145
    • Minneapolis, MINN.
    ok, so got the 79 up and running, all the fuel lines are correct, valve clearances are within specs, and everything seems good, except when i rev the engine, it often stays around 4000 rpms, and wont go down unless i change the idle screw. it will then repeat regardless of where the idle screw is. so my question(s) is, is this due to the carbs being out of sync/needing tuning? or does the jetting need to be switched around? (stock exhaust, mikes xs pod filters) one other thing is, the plugs were a bit oily and needed to be wiped clean before the bike started again. idk if thats just because of excess oil in the engine from the rebuild, or piston rings or what, but i'm going to start it again and check the hot compression numbers later today.
    (i put some marvel mystery oil in the oil, and a bit of seafoam in the non oxy ethanol free gas too, so idk if that would change anything either...)
    1979 xs special, just finished the top end rebuild and then i still have lots of work.
    progress thus far...
    http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
    "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
    Have you done a sync yet? Have you adjusted the idle fuel mix yet? Those are the biggest causes of a hanging idle.
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Don't bother with a compression test until the rebuild is broken in. The rings need some time to fully seat and seal to the cylinder walls. sync the carbs now and then again after the break in of the engine. Check for "hang ups" in the carb linkages and make sure each carb butterfly valve will snap closed under the spring pressure of the butterfly spring when standing alone off the rack. Any binding of any butterfly valve will affect the entire rack. Don't start jetting until you are sure the carbs are working properly.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
