drags, that is WAY cool. Get a close up though, I had to look twice at the photo.
OK, gotta have one of them. Wonder if that's legal in PA?
I got my springs from MAW on line, $58 or so and around $20 for shipping. They are still list some limited parts for the XS, including exhaust stuff.
http://www.accwhse.com/
I am probably going to order 13 1/2" shocks from them. Those new JC Whipme ones I bought to get me through the fall last year are too short.
Tkat sells his fork braces occsasionally. He gets the urge and the time, announces to all they are being make, and then takes orders. I believe he gets $85. You will have to go to the other XS site on Yahoo, that's where he hangs out, and I believe he is taking orders now. They are made for the XS, they are not a universal thing. One for the standard and one for the special. Very nice work, and they work very nice. Ever notice the wandering in a curve when you are getting on it a little? This brace takes a lot of that out. Some have posted here that the F/B improved their straight line tracking, although I did not see any change there.
pgg is it possible you have another problem? Fork oil too heavy? Something else? Last spring I was having a tough time with the forks, some bumps would jar the heck out of you, the wheel acted like it was out of round sometimes, and the biggest problem was the dive when I hit the brakes, even at very slow speed. Clymers says the springs are worn out at 19.82 (503.4mm)inches, mine were 19.65-ish (500-ish mm). I forgot to measure the new ones, but they stuck out of the top of the forks about 2 inches before I screwed the caps on, where the old ones I had to reach down into the tube to remove.
Major difference in ride. Smoothed out everything, made the ride much more enjoyable. Sweepers were much more controllable. BTW I use 15 wt fork oil. Clymers says 10 wt is good, some here have posted they use higher values.
