Got a new upgrade for the judge
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    hey guys i got my new dyna coils dc2-1 1.5 ohm coils in the mail today. i never made my own plug wires. so i got them cut to length but now i got to get the crimp ends on the wire.....do i need a special crimp tool? i have one but it way way to small...maybe someone has a link on how to install these...or should i make one
    1980 gs1000g "stock"
    Lee,
    From what I've seen of spark plug wires, you need to strip back a section, about 1/2" from the end that will be going into the coil, you then fold the inner wire over the end of the insulated end, slip the metal end over the folded wire and insulation, squeeze it together with a pair of pliers, there's usually a point that sticks out inwards towards the wire when you put the metal tip on the wire end, it sticks into the insulation to keep it from slipping off. The metal end has some spring action to it, and when you push it down into the coil end, it gets compressed/squeezed as it fits in. You should also have a rubber slip cover that fits over the wire and down around the knob/tower that's sticking out from the coil body that the wire is fitted into, it slips over that to make a fairly water tight seal.
    The plug end should just screw on like the OEMs, but you may have to strip back a little of the outside insulation, not down to the wire, but just a mm if you have real thick/fat wires so that it will fit/screw into the end of the plug cap.
      • 3193
      This is what I got with my Accel wires. They sent the crimping tool with the set of coils and wires.
      • lee_dutcher
        • Apr 2009
        • 822
        • mason city iowa
        Ok i got figured out tc... here is my progress[IMG][/IMG]....
        [IMG][/IMG]
        Next thing i need to figure out is how to mount them....any pics of what your L brackets looj like fellow xsives?
        • Joab
          • Aug 2010
          • 472
          • Ozark, Alabama
          The coils should be pretty easy...but mounting that Superfood is going to be tough...
          Joab
          "If nothing else, it will be interesting..."
          ______________________________________________
          1979 XS1100SF
          1972 XS2 650
          Ozark, Alabama
          • lee_dutcher
            • Apr 2009
            • 822
            • mason city iowa
            Hey that is awsone stuff. On sale for 1 buck at wally world. Uselly cost about 4 bux a bottle...got 20 of them...
            • Joab
              • Aug 2010
              • 472
              • Ozark, Alabama
              Oh man, I wish ours had that deal going on!
              Joab
              1979 XS1100SF
              1972 XS2 650
              Ozark, Alabama
              • GLoweVA
                • Jun 2011
                • 1957
                • Virginia Beach, VA.
                Hey Lee, is that green wire in the pic a headlight relay jumper ?!?
                I've got mine jumpered too.
                80G (Green paint(PO idea))
                The Green Monster
                Got him in '04.
                bald tire & borrowing parts
                Scarlet
                Got her in '11
                Ready for the twisties!
                81H (previously CPMaynard's)
                Hugo
                Cold weather ride
                  Hey Rasputin, that's a great guide sheet, thanks for posting it.
                  Lee, I just realized that the photos I had linked to the "BAD" MikesXS Black coils were lost when I changed my ISP. I'll get them back up later today. But it's just as stated....they are L shaped...but because of their size and the limits of space, I had to angle their position so that they actually are slightly slanted front to back, they are not parallel to the frame tubes.
                  They will bump against each other if you have the L brackets positioned so that the elbow of the L is on the inner location, so I position 1 like an L, the other like _| so that the coils metal center is positioned OUTSIDE of the L vs. Inside the L. Hope that isn't too confusing. Gotta go eat breakfast, will get the photos up soon.
                    Hey Lee,
                    My photos really won't be much help, but this tech tip from 2003 will!
                    He used longer/wider L brackets, so it depends on how much space you have in there when you try to position them as to how you orient the L brackets and the coil bodies.
                    • lee_dutcher
                      • Apr 2009
                      • 822
                      • mason city iowa
                      yes that is the jumper wire to the hedlight relay. and Thanks for that link that will help alot... is that in the tech tips if not it should be....
                      • lee_dutcher
                        • Apr 2009
                        • 822
                        • mason city iowa
                        nevermind found it in the repair tech. thought it would of been in the modification tech
                          Yeah, some of these need to be shuffled around a bit, that's on my list of things to do....
                          • WSL91
                            • Feb 2012
                            • 427
                            • Quad Cities, IL
                            I think I would have mounted them before cutting the wires
                            Nice upgrade!
                            1970? Honda Z50... gone
                            1974? Yamaha 100 Enduro... gone
                            1974 Honda CB200... gone
                            1981 Yamaha Virago 750... gone
                            1993 Honda Shadow 1100... gone
                            2008 Honda VTX 1800F
                            1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                            1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                            http://www.johnsoldiron.com
                            • mikubuilder
                              • Jul 2011
                              • 548
                              • Westland, Mich.
                              +1 on that...post pics
                              Nick
                              1982 Virago 750 (it's alive!)
