Synced carbs, idle now 3K-4K
    • 9981
    Originally posted by skids
    I dare say that it is impossible to get a descent synch for carbs with only the fuel in the bowls! You need to either run a line(s) to the tank or get an auxiliary tank.
    A big +1 on that.
      • 8062
      The RPM went down when I pushed between the carbs because the center adj screw was not against the plate.
      I think it's such a mess because it wasn't even close when I took it in.
      This time I'm going to eyeball it and call it good. If the idle is steady, I won't mess it up again.
