My 79 standard has a miss fire that is proving to be difficult to find the cause of. Carbs are clean as a whistle, Plugs are burning as close to perfect as I would want to see and a color tune shows good even color across all 4 cylinders but I can see the miss with the color tunes in place and with a timing light.
This miss is erratic. It is happenstance and appears at any and all throttle positions. It is not enough to kill the engine and the bike actually pulls pretty good but can see the miss in the tack. I already checked the ignition unit by changing it out with a known to be good unit, fuel supply is good and gas is right out of the pump.
This bike ran flawlessly right up until spring of last year and nothing had been changed.
I'm very sure it's not a carb issue given the color tune results and the plug condition. I have not as yet checked the pick ups but they were NOS units that were installed less then 5K ago
I'm close to stumped. WHAT NEXT?
Rob
Rob
Rubber doesn't age well, and at 30+ years old, I wouldn't expect it to hold up for very long or very well!
