New tire time
    • 5061
    I quit using the Bridgestone splitfires because the harder compound around the center does not grip wet pavement good enough. Also, they crack around the sidewalls which makes me nervous.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      new tire arrived, but I've got a problem!
      Okay so I go to pull the wheel off today and I can't get the axle out! It'll twist around but it's hung up somewhere between the wheel bearing and the caliper bracket. I even tried pounding on the other side (where the spindle nut is) using a 3lb sledge!
      I'm totally stumped. There's got to be something wrong with how I put it together a year ago.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        • 9980
        There really isn't anything for it to hang on in there. All I can think of is the bearing has gone bad and welded the inner race to the axle.
        One way or the other it has to come off there. Keep working it.
        • Nightengale
          • Jun 2011
          • 521
          • Hampton, VA.
          #34
          heat
          do you think heating it up with a torch might help??
          xs1100 hartail bobber
          http://i1169.photobucket.com/albums/...-38-36_563.jpg
            #35
            could have rusted to the bearing.
            Going to have to just keep beating it.
              Please tell me you took the pinch bolt off.
                • 9980
                Yeah, if you go back in the thread you'll see where he can turn it but it wont slide out.
                That was my first thought too, he might be pulling a Brent.
                • GLoweVA
                  • Jun 2011
                  • 1957
                  #38
                  I can get it to move about a 1/4" and no more. I'm all out of ideas. The only thing I can think to possibly do now, is to pull the swing arm apart.
                  If I hammer away at the left side all I'm doing is messing up the axle bolt and the alignment. If i get the whole swing arm off the bike then I can pull the final drive off and have better access to the axle.
                  The Green Monster
                  Got him in '04.
                  Scarlet
                  Got her in '11
                  Hugo
                  Cold weather ride
                  • CaptonZap
                    • Jun 2010
                    • 1748
                    • Denver
                    #39
                    Well, no.
                    You will still have to remove the axle before you can remove the final drive.
                    But you will be able to put the offending axle in a press, and not screw up the threads. Good luck, CZ
                      • 9980
                      I wouldn't worry too much about the axle at this point. More than likely it's already FUBAR. Be careful with the wheel.
                      Lots of axles out there. I've got a few.
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        #41
                        Got it off!
                        So after beating the hell out of it it finally came out.
                        I might have messed up the threads and the nut is definitely fubar.
                        After cleaning up the shaft it slides in and out just fine. Just dirt and a little rust.
                        It's amazing what pb blaster will do.
                        The Green Monster
                        Got him in '04.
                        Scarlet
                        Got her in '11
                        Hugo
                        Cold weather ride
                          #42
                          Well, George is probably home getting some rest, he was able to come by with the wheel/tire and the fairing bracket, got the tired changed in about 15 minutes, static balanced it on a pair of jackstands with the axle. Then we welded up his fairing bracket. We'll be getting together on the bikes tomorrow and meeting up with Nightengale and possibly also drop over to see KeithH on the way back.
                          • GLoweVA
                            • Jun 2011
                            • 1957
                            #43
                            Thanks TC.
                            First thing in the morning I'm putting it all together and going for a ride.
                            The Green Monster
                            Got him in '04.
                            Scarlet
                            Got her in '11
                            Hugo
                            Cold weather ride
                            • Nightengale
                              • Jun 2011
                              • 521
                              • Hampton, VA.
                              #44
                              Thanks TC.
                              glad to hear everything worked out.
                              • GLoweVA
                                • Jun 2011
                                • 1957
                                #45
                                Thanks John. Hope to get it together early so TC and I can get up to your place by late morning.
                                The Green Monster
                                Got him in '04.
                                Scarlet
                                Got her in '11
                                Hugo
                                Cold weather ride
