850 final swap 150 mile review
  • WSL91
    • Feb 2012
    • 427
    • Quad Cities, IL
    I finished my 850 final swap yesterday and have since put 150 miles on the bike. I bought the XJ in mid-February and have steadily been working through examining and servicing every object on the bike. I’ve rebuilt the calipers and master cylinders, changed a tire, de-linked the brakes, fixed the fairing, added fork spacers, etc. I really was having trouble with the idea of not checking the swingarm and wheel bearings. I had an 81 Virago that the swing arm bearings failed on so I’ve been looking for a reason to check these.
    As far as the install itself of swapping the final and making the necessary changes it’s not bad. I chose to pull the rear swing arm and all related parts as well as the rims for refinishing. This small addition makes for a LOT of additional work. All the parts were showing their age so a lot of elbow grease, some sandpaper, and some paint made everything look much nicer. I also cleaned the calipers with 3M scouring pads and re-painted them. Upon re-assembly I was able to work some new grease into the wheel and swing arm bearings!
    On the final I took a grinder and knocked down 6 of the ribs to make them look like the 1100 final. It’s not going to be easy to spot the 850 final in this one. All the parts were painted with rattle can epoxy paint.
    On the first ride it was immediately apparent that the gearing was different. I must say 1st gear is a tad high for my liking. I feel like I've traded 1st for 6th. On the first ride I nearly dropped the bike as a result. I was making a hard right turn into a business and I let the RPMS drop too far and stalled the motor. While leaning right the bike immediately wanted to drop right and I was able to put my right leg down fast enough to act like a pogo stick and 3 hops later had the bike stopped. It all happened so fast I didn’t even have time to think, just re-acted. Had I been on my 850lb Honda it probably would have ended up on the pavement. A side from the tall 1st gear everything else if fine. I ride in a medium size metro area with a mix of regular surface streets and expressways. I still prefer the 850 over the 1100 with in town driving.
    Tonight I headed out for a town 45 miles away and can report the bike really performs well. I can’t get over how much better the gearing seems to fit, what a well manured ride now. I have to think this is what the bike should have been delivered with. 65 mph now revs at 3900rpm, not 4500. On my first fill-up since the swap mileage went from 35mpg to 40mpg but I'd really like to see 45mpg. About the only thing left to address on the bike is a good carb cleaning and I’ve picked up an extra air box and will be looking to mod it for a more modern filter element. I have an XJ and don’t like the idea of hard to locate 50.00 air filters. Final comment is it receives John’s 2 thumbs up review and no going back for me.
    FWIW the Honda VTX guys are doing the same thing for the same reason. I've swapped rear end on my 1800 with the 1300 rear end and don't even drop into 5th until 60mph now but then that ride doesn't red line at 8500
    1970? Honda Z50... gone
    1974? Yamaha 100 Enduro... gone
    1974 Honda CB200... gone
    1981 Yamaha Virago 750... gone
    1993 Honda Shadow 1100... gone
    2008 Honda VTX 1800F
    1982 Yamaha XJ1100J w/850 final, Raptor ACCT
    1979 Yamaha XS1100SF "Chewey" Raptor ACCT
    http://www.johnsoldiron.com
    You get used to the 1st gear quickly. I rode another XS the other day that still had the stock FD and 1st gear seemed WAY too low for me.
    The 850FD is way smoother to ride.
    Does that mean it's good $hit?
    • ddragon63
      • Jan 2012
      • 1101
      • Ridgefield, WA
      i'm REALLY interested in doing this swap. As my XS is more of a freeway and open Hwy cruiser I think it would be beneficial. But it does sound like a lot of work... not a fan of that 4 letter word WORK
      Don
      old:
      1989 kawi ex500
      1996 yzf-r6
      1999 yzf-r1
      2001 kawi zx-6r
      2000 Ducati 748
      2002 YZF-R1
      2005 V-Star 1100 Classic
      • Joab
        • Aug 2010
        • 472
        • Ozark, Alabama
        Aww, you beat me too it Greg!
        I am looking forward to performing this swap, just need to get that brass sleeve made.
        Joab
        "If nothing else, it will be interesting..."
        ______________________________________________
        1979 XS1100SF
        1972 XS2 650
        Ozark, Alabama
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          good after you do yours I'll run down to 'Bama and you can do mine. The 2 of us together working on a bike.... what could go wrong
          plus 'Bama's just around the corner from WA right?! LOL
          I may tackle this swap after this season. We'll see. I gotta get it up and going thru this season first
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
          • Joab
            • Aug 2010
            • 472
            • Ozark, Alabama
            I may tackle this swap after this season. We'll see. I gotta get it up anyed going thru this season first
            Ha! I would have to buy a new fridge to support the amount of beer it would take the two of us to get through a project together! And I am not sure my garage walls could take that level of launched projectiles!
            And yeah, Bama right there...a saturday afternoon ride really...
            Joab
            1979 XS1100SF
            1972 XS2 650
            Ozark, Alabama
            • WSL91
              • Feb 2012
              • 427
              • Quad Cities, IL
              Google spell check.....
                If you don't take the swingarm off, it's a really simple, pretty much bolt-on job of maybe 30 minutes? The biggest problem I've ever had with it was getting the driveline back up into the yolk on the U-joint. Getting the splines lined up and getting it past that little spring clip can sometimes be a pain. The worst part about the job was smelling something horrible, and realizing the old final drive had fallen over and was spilling that old stinking burnt fluid on my garage floor.. lol.
                  +1 to that! It's really a simple project. Most of the "work" is making the little collar, then trying to get the shaft to seat in the u-joint.
                  • WSL91
                    • Feb 2012
                    • 427
                    • Quad Cities, IL
                    If I'm not mistaken the how to says to discard the clip. The shaft won't be insterted far enough now for the clip to be effective.
                      Yup,that's right. Throw that thing away, it's as usless as the grease fitting for the splines. It does nothing.
                      • DAVINCI
                        • Jan 2011
                        • 1048
                        • Cedar Mountain, NC
                        150 miles? Pfffffttt.
                        I've got something like 20K on mine and it's the best thing I ever did to the bike.
                        • Cuda 69
                          • Jan 2012
                          • 676
                          • Greenwich N.Y.
                          I think I could do that,hook the thing-a-magigy to the what-ya-macallit.
                          FOXS-XS11SG
                          1980 XS11SG-sold
                          1999 Vulcan classic-sold
                          1982 XJ 650-sold
                          • DAVINCI
                            • Jan 2011
                            • 1048
                              Don't ride much do you Randy? Bet I got half again as much as that on mine, maybe more.
                              I've been trying to warp that housing too and I guess my engine just doesn't have enough power.
