Interchange Guide: Frames, Stands, Rear Fenders
    Ok, here's the first installment of the interchange guide. I'm going to break these into assemblies, both to reduce the size of the thread and to make finding specific info easier. I'm looking for feedback, so if you know of a difference I've missed that will affect interchange or make indentification easier, post it. Documentation will be very helpful (pics). Remember, this isn't a how-to or a guide to non-XS parts that may fit, this is strictly to help in determining what XS11 parts will interchange.
    Let me know what you think!
    Frames
    All XS frames (and the XJ too) share the same basic architecture and design, but there's enough differences that swapping them is difficult. There's two basic XS 'types'; standard and special frames. While at a glance they can appear identical, they most definitely aren't the same. Things that are the same for both types are the neck, motor mounts, side and center stand mounts, swingarm, fuel tank, shock, seat and coil mounts. The XJ shares all this except for the seat and fuel tank rear mount, but there's enough 'other' differences that this frame won't interchange with any other. The two major differences in the standard and special frames are shown below...
    Rear fender mount, Special at the top. Completely different, this prevents swapping rear fenders between the two versions. The accessory mounting holes are also located slightly different (see arrows), so luggage racks and sissy bars may not interchange. Note that the Special frame has been modified at the turn signal hole, normally this would look the same as the standard.
    This is the back-breaker; different mounting points for the muffler/rear footpeg supports, as well as a different brake linkage design; standard frame at the top. The arrowed holes are not in the same place, and the Special frame has the brake pedal pivot, where the standard has that as part of the muffler support. The supports/linkage will not interchange between these frames.
    Other details on the different frames:
    '78-79 standard. The only two identical multi-year frames; these can be exchanged with virtually no issues. Includes brackets for storing the 'emergency kick lever', and has a single horn mount. Side cover mounts only accept matching year/model covers. Will have 2H7 stamped on the neck.
    '79 special. One year only. Has the kick lever brackets and single horn mount. Side cover mounts accept '79 special cover only on left side, '79 special and '80-81 standard cover on right. 3H3 stamp.
    '80 standard. One year only. Kick lever brackets are now gone, horn bracket is changed for dual horns. Two additional electrical brackets, one for the relocated main fuse and one for the 4-way flasher. Side cover mounts accept '80-81 standard covers, '79 special cover on right side only. 3H5 stamp.
    '80 special/Midnight Special. One year only. Same changes as the '80 standard, but side cover mounts only accept '80-81 special sidecovers and now has mounts for front reflectors. These two models have different stamps as the MNS frame featured better 'finish' compared to the 'plain' special so look for 3J6 on the special frame and 4H3 on the MNS frame. These are otherwise the same.
    '81 standard. One year only. Basically the same as the '80 standard with two minor and one major difference; the minor items are additional brackets for a 'locking cable' box and the deletion of the ballast resistor bracket. The major change is the standard is now using the special exhaust, so the muffler/footpeg supports and brake linkage is now the same as the special. This frame will not interchange with any other. 4R1 stamp.
    '81 special. One year only. Same as '80 special frame except for deletion of ballast resistor bracket. 4R0 stamp.
    '81 Midnight Special. One year only. Same as '81 special except for additional brackets for locking cable box and linked brakes, better finish. 4W1 stamp.
    There is interchanges possible in the '80-81 special frames as long as certain brackets aren't needed or you're willing to make the needed mods. But for direct one-for-one interchange, this is it.
    Rear Fenders
    The top pic is 3 of the 4 fender types. These are (left to right) '78-79 Standard, '80-81 standard, and '80-81 special; not shown is the '79 special. The rear fenders follow the frame, so you have the two basic types, standard and special. The major difference is the standard fenders are hinged for tire removal; the lower pic is of the standard frame mount/hinge. There's two variations of each type; the '78-79 and the '80-81 in the standards, with the only differences being the early fender has mounts for the TCI unit and the bolt holes to the frame are threaded; the later fenders use a nut. The special has the '79-only rear fender, and the '80-81. The '79 unit is the same as the one shown except set-up for a taillight mount similar to the standard so will have holes like the standard fenders shown, the late units as shown only have have a license plate mount/light as the taillight mounts to the cast aluminum grab bar.
    Battery Trays
    Fully interchangable in the XS bikes across all years/models. The XJ tray is XJ-only and on the right in the pic.
    Side/Center Stands
    These follow the type of exhaust fitted, so the '78-80 standards use their own side/center stands, the specials, '81H and XJ all share the same units. The standard model stands won't fully retract with the special exhaust as they'll hit the muffler first.
    Standard centerstand on top, Special/'81H/XJ on the bottom. Both are the same height and mount to the frame the same, difference is the 'foot' arm. Distance from the frame mounting bracket to the inside of the pedal is 4.75" for the standard, 6.25" for the Special. Check this if your bike is fitted with a non-stock exhaust to see if you have enough clearance. For you restorers, the XJ stand has one minor difference; the foot pedal is a flat stamping, not the rounded one as used on the XS stands.
    Sidestands, same difference. Height is the same, longer 'arm' on the Special/H/XJ units.
  • Stralya
    • Apr 2006
    • 791
    • 'Blotto Grotto' Wodonga, Victoria, Australia.
    Frame measurements
    G'day Steve,
    I've found an engineer willing to make up a tow bar for my '78E and he needs the rear frame measurements. Any idea where I might find this information?
    Thanks,
    Dan
    Automotive Imbecile.
    Proud owner of 'The Swiftcicle'. (Swifty for short)
    '78E Full Vetter Dresser.
    1196 Big Bore Kit.
      When you say 'tow bar', do you mean a trailer hitch so you can tow something behind the bike, or something so you can tow the bike behind something?
      If what you're looking for is a dimensioned drawing, I've never seen one. If you're trying to build a hitch, several posters have done this and there are some pics posted here that could give you ideas. What type of exhaust you have will be a big factor in the design, as well if you're running with a luggage rack or saddlebags.
      I built one for my '78 years ago (since sold, so no measurements, sorry), but do have pics of it so I could give you some guidance on design. PM me if interested....
      • Stralya
        • Apr 2006
        • 791
        Trailer hitch, yes. I've bought a trailer. I'm taking the bike to the engineer on Tuesday afternoon to let him measure it up. I have a mac 4 into 2 system and full Vetter set up. I've already sent him some pics of one already made up so he has some idea what he will be making. I assume the mounting points will be the rear footpegs (main load point) and the top shock absorber connection points, would this be right?
        Dan.
        1196 Big Bore Kit.
          Here's a thread where this is discussed... http://www.xs11.com/forum/showthread...r+hitch&page=2
          There's several other threads too, but the main points are covered in this one. Basically, you want to tie the hitch to the rear footpeg or muffler mounts (the muffler mounts have that rubber isolator, so that does help with 'shocks') and the 'accessory' holes right behind the rear turn signals. Keep the trailer tongue weight down (20 lbs max) and you'll have no issues with frame strength. Do try to set the hitch up so it's easily removed, as you'll have to pull it to change the rear tire....
          • Stralya
            • Apr 2006
            • 791
            Thanks mate, I'll pass this on to the engineer Tuesday.
            1196 Big Bore Kit.
