where to get carb rebuild kit
  • Mojo75
    • Mar 2012
    • 34
    • Asheville NC
    I'm gonna be buying a rebuild kit soon and wondering where you guys would suggest i buy? any idea what all 4 should cost?
    I just bought four kits from George Fix for $70. I couldn't find a better price. He ships immediately. They sent me K&L kits.
      He's the best price, and pretty much all you'll find are K&L kits anyway. You can buy everything separately but that will get expensive. The issue with these kits is the furnished jet needles have been reported as causing problems as well as the main/pilots jets. Genuine Mikuni jets seem to work better, the jet needles are NLA so unless your's are heavily worn or damaged, reuse the stock ones.
      The kits are a decent deal because they include the bowl gasket, float valve and seat, and new idle screws (besides the other jets) all of which will probably need replacing. Buying these separate can be the same $ or more as a kit.
      DO make sure the furnished parts match what you pull out, as there have been problems with incorrect jets in the kits on occasion.
      • Mojo75
        • Mar 2012
        • 34
        • Asheville NC
        thats much better than i found!
        • Mojo75
          • Mar 2012
          • 34
          • Asheville NC
          if i buy that kit would it be easier to just but Mikuni jets? what size do i need?
            You can't get an answer to that question unless we know something about your bike.
            What model is it? (ex. XS1100E, XS1100SF....etc.)
            What modifications exist? (ex. pod filters, aftermarket exhaust,...etc.)
            With those questions answered, someone can give you a guess where to start.
              That depends.... Are you doing a straight rebuild and your bike is all stock? Or has it been modified with aftermarket exhaust and/or air filters? Different jetting can be needed if it's been altered, but if the bike is still stock you can probably just clean the original jets and reinstall them as long as you don't booger them up getting them out.
              Jet sizes vary with year/model/carb type, you need to know what you have first...
              • Mojo75
                • Mar 2012
                • 34
                • Asheville NC
                as far as i know its stock with the factory jets and pipe. i need to tear apart and take a few more pictures
                  What model, or at least, what year model is your bike?
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    If you haven't torn it apart yet, you may not need an entire rebuild kit. Save some money and clean those brass parts good and you may not have to replace them.
                    When I got my project bike, the carbs had been sitting with gas in them for over 5 years. I was expecting sludge, instead I found green corrosion. It took me 4 times with the carb cleaner and various pics and poking wires, but I got them all clean and good to go. (execpt the float needles/valves. I couldn't save them)
                    Even my gaskets were okay.
                    Just be careful when you take it apart so you don't break anything and you can probably save it all.
                    Even if it's just one part you need, maybe someone here has that piece that broke (or just can get right).
                    I don't want to discourage you, but you will get to know your carbs, you'll probably be seeing a lot more of them. Every time a gets a little easier though.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
