jetting opinion
    • 7761
    jetting opinion
    I hope this isn't like opening up about oil or tires, but.....
    When I went through my carburetors last year they were jetted 110-120-120-110 when it was done. I have only the Clymer book and the '78 FSM.
    My SG is running the stock airbox with a K&N filter in it. I have 4 into 1 exhaust. It has been running well. The plugs look more gray than brown, but who knows with this blended fuel.
    I have to take the carbs off again and replace the float valves due to chronic leaking. I have the K&L kits from George Fix. Should I use the jets in the kit to go 120 across, or "don't fix what ain't broke"? Or?
    Marty, if it were my bike I'd go to 115s across. 120s are 4 sizes up and a bit much IMO, but every bike is different....
      • 7761
      Thank you, Steve. If I have those in the kit, I'll take that advice.
      Where would you go if the kits have only 110 & 120?
      I'm going to have a close look at the plugs. I don't know if I'll be able to see a difference between inside and outside plugs as it ran a bit at idle before I parked it, combined with my 15 mph speed in the neighborhood.
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        After you put new/different jets in, you'll obviously re-sync to get everything balanced again.
        Then you can look at the trend that the new jets give you.
        Look of the plugs, performance, gas milage, etc.
        Compare these to what you had before and decide if you want to stay with those jets or not.
        I think it's funny & ironic that 'JET' Marty is messin' with his jets!
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          • 7761
          How about that! The jets I'm usually messing with are of a much grander scale!
            Your local metric bike dealer should have or be able to get genuine Mikuni jets; they're not much money, less than $5 each IIRC...
              • 7761
              Excellent!
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                Marty I agree with Steve on the jetting but given that you have some color on your plugs you are definately not running lean like I was. My plugs were bright white and my pipes blued all the way back to the joining point. I went one step up from 120 to 122.5 and now have a litle yellowish brown and the pipes and cylinders are not running as hot as before. If you need 2 115s I can send them to you if you PM me an address. I have a 1980G so you can cross reference the parts for fit. really you need to get on the road and run it a little before you can count on the color of the plugs for setting jetting. Idling it typically can give you very misleading results as it primarily uses the idle mixture when idling.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                Barnett Clutch Springs
                R1 Clutch Fiber Plates
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                  If original model year carbs on both bikes, The metering rods are different size/configuration between the 80-81 Special and Standard.
                  • ViperRon
                    • Feb 2011
                    • 1062
                    • Woodstock, VA
                    Moto man
                    Main jet (115) 620 14231 23 A0 for G and SG
                    G and SG are both 1980 models just different jet size recomended as SG is 120 and 125 and G model is 115 and 120
                    620 14231 23 A0=115
                    620 14231 24 A0=120
                    620 14231 25 A0=125
                    Yamaha part numbers that is what I found.
                    Rodan
                    1980 G Silverbird
                    1198 Overbore kit
                    Grizzly 660 ACCT
                    122.5 Main Jets
                    ACCT Mod
                    Mac 4-2 Flare Tips
                    Antivibe Bar ends
                    Rear trunk add-on
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      Marty, before the FI, I had 4-1 with pods and with the wideband O2 sensor, found that 117.5's where just right. So, with your setup Steve should be right on with 115's.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                        • 7761
                        I'm into this job now. My camera is MIA.
                        Jetting is 110-120-120-110. The plugs are light gray to white. 2 & 3 are whiter than 1 & 4. What gives?
                        For the time being I'm stuck with no transportation. Any suggestions?
                        I have verified the jetting. Carbs are open and I'll have to look at spare XS650 carbs to see if they have anything to offer.
                          • 7761
                          I have four main jets that are 132.5. Too big?
                            • 7761
                            My K&L kits did not come as advertised. I have 120 & 125 available.
                            Should I be thinking about moving the needles? The bike is runnig very well, but I don't like the white plugs.
                            • jjz28
                              • Apr 2012
                              • 1023
                              • Beckley, W. Va.
                              I just got my first 79 xs1100sf special, what size are the factory jets? Mine has 137.5's in it and it runs good. I know it has different pipes.
                              77 XS750 2D completely stock
