I purchased an XJ in Nov with 15K, need lots of tlc.
When I cleaned the front caliper it ran well. With it I got new carb manifolds. When the weather got cold I decided to clean it up and put on the manifolds. I have removed and polished all aluminum, crank covers too, except the shocks and fork tubes. Just cleaned on the bike. Have done the Nyalic thing to all. Checked out second gear while down, looks good. Changed all fluids except fork oil. Had to replace the tach as well. Cleaned outside of carbs, removed bowls one at a time, very little residue in bottom, blew out with carb cleaner and replaced. Discovered that air intake nozzle was out of air box inside and allowing air to bypass filter. Filter was probably original. Dumped the gas, did not look good. Now all back together and flood out the air box. Pulled carbs ( a little silicon sprayed on the boots helps) and found #4 float hanging. Carbs back on and no leaks. Fired up, warmed a few minutes, Idle is a little rough and will not rev well, sounds like slight popping out the right exhaust almost like slight backfire. Well out on the road, a little rough at start, but open the throttle and good by. So I have a low speed circuit problem?Where should I look?
