an oil question
  • warfman41
    • Mar 2012
    • 22
    • Glasgow ky.
    an oil question
    Hey guy's, I just bought a 1979 xs 1100 standard that had been sitting for some time, and was looking on here about oil type suggestion's so i could change the oil in the old girl. Saw a post on here by someone that people were having good luck with mobil 1 15w 50 synthetic oil, so that's what i used in it. But... i just read a post where a fellow was having clutch slippage problem's using synthetic oil. I'm new to the xs 11 community, could someone help me out and tell me if i should lose the synthetic oil before it cause's me problem's? thank's
    Warfman41 1979 xs 1100 F newly aquired...getting it road ready.
    Synthetic pretty much always causes the clutcg to slip(a rare few have.made it work but that is usually only with new clutch friction discs). 20/50 mineral oil is the correct oil to use. Make sure whatever oil you do use does npt have friction modifiers in it as that also will cause clutch slip.
    So I would say dump the synthetic, especially on a new to you bike.
    • Lonerider62
      • Nov 2011
      • 187
      • Gaylord, MI.
      Just make sure it's a motorcycle oil (no friction modifiers) and you'll be OK. The problem with using an automotive oil in a bike with a wet clutch, fed by the crankcase, is obviously a friction modifier in the lubricant can be detrimental to the friction needed for proper clutch plate action.
      Can't beat the smell of gas & oil
      • warfman41
        • Mar 2012
        • 22
        • Glasgow ky.
        thank's
        Thank's very much for the info guy's. I think i screwed up, because it's an automotive oil that i used, so i think it had better hit the old drain pan. lol probably switch to 20w 50 castrol. Again, thank's for the response.
          +1 on what Nate says. BTW......WHERE'S THE PICS??????
          • warfman41
            • Mar 2012
            • 22
            • Glasgow ky.
            pic's
            Hey Greg, gonna get some pic's on here soon. Had to run me down a sidecover, got lucky and found one on Ebay. Kinda want to get it painted and on the bike before i put the pic's on here. Want the old girl to look her best before she go's to the ball...
            • Kevin W
              • Mar 2007
              • 68
              • Southwest Chicago suburb
              Warfman41,
              The only time I experienced ANY clutch slippage was at high speeds, high rpms. I'm actually a fairly conservative rider so I only experienced it a couple times the whole time I rode it! That's not very much. I read a post somewhere on here that says that the synthetic oil cleans things up in the engine so maybe you want to run it in there for a few miles?
              fwiw
              KW
              1982 XJ1100J
              1980 XS850SG
              • warfman41
                • Mar 2012
                • 22
                • Glasgow ky.
                thanks kevin
                Yeah Kevin, I think that would probably be a good idea. Haven't got to ride the bike much, just around the country road's here where i live, but the clutch doesn't seem to be slipping at all. I think i will run the oil for a few mile's, then probably switch over to 20w/50 castrol. Kinda hate to drain it right out, since it cost almost $9.00 a quart. Thank's for the input friend. Warfman
                • New2Me
                  • Jun 2011
                  • 91
                  • Morris, IL.
                  Noway you got to show the before picture so we can appreciate the work you put into it. Not that we wouldn't anyways.
                  -4:2 exhaust
                  -Pods
                  -Who knows what the future holds..
                    • 6763
                    There should be a circle type symbol on the back of each can if it says energy conserving...then you DO NOT WANT THAT...The friction modifier is usually Moly..you want NO Moly. It matters not if its synthetic or dino.
                    2005 Honda SilverWing 600
                    2018 Honda PC-Xpress 150
                    • ddragon63
                      • Jan 2012
                      • 1101
                      • Ridgefield, WA
                      Plain old Castrol or Valvoline 4T 20w-50 motorcycle oil. You can get one or the other @ auto zone or wal-mart. Usually Wal-mart havs the Valvoline for under $4 a quart. I put 10 ounces of Lucas oil stabilizer in with my oil in the XS too... In my personal experience it helps keep the viscosity of the oil from breaking down as fast, helps quite the gear box too. If your going to use some Lucas in your oil DO NOT put more than about 12 ounces in it. Your clutch will wanna slip with the extra slick stuff. I like to pretend it helps keep the oil stuck to my cam chain so it will last longer Not everyone will agree with me... but i'm use to that
                      Don
                      old:
                      1989 kawi ex500
                      1996 yzf-r6
                      1999 yzf-r1
                      2001 kawi zx-6r
                      2000 Ducati 748
                      2002 YZF-R1
                      2005 V-Star 1100 Classic
                      • airborneXS
                        • Feb 2012
                        • 338
                        • Houston, TX.
                        ive been using the lucas oil with lucas motorycycle oil stabilizer in all my bikes, never had a problem....i get some people calling me a fool and others calling me a genius, but ive never had a problem, that is except for when the wife ran her bual OUT of oil...lol
                        79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
                        09 YZF-R1 " Toothless"
                        04 Buell XB12R "Butterfly"
                        "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
                        Wolf
                        Moto Militia MC
