Carb tuning disaster
  • Carb tuning disaster
    So I'm playin with the sync and tune of the carbs and #2 is just being a PITA to adjust mixture... So I pull mixture screw.... BROKEN clean with the hole! Awesome! I'm off to my store to find the right sized pin drill and stop @ the bike shop to see if he has mixture screw. Anyone had any success in removing one without pulling the carbs? And if does anyone have a mixture screw to throw down to a brother if I can't find one local?
    All help appreciated
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
    Nope, they gotta come off Don. That means starting over again.
    PM me yor address.....
      No matter how you go about it, you will need to pull the carbs. Drilling it out in place would put all those shavings in your engine. Pushing it through would put that in your engine. You need to get to the carb throat which means pulling them out.
        The brass or aluminum would really be inconsequential to the engine but the carbs really need to come off to get to the thing as Don said.
          I do not reccomend drilling. Try the freeze method and push the tip out
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
            Perfect... K I couldn't find one locally So I went out and Flogged on the R1 for a while to calm down. I couldn't figure out why it ran better the more Vac i took away from #1 and #2 and why 2 kept reading WAy lean @ idle...well that explained it. Greg I'm sending you a PM. Thanks for the help guys. I will be pulling the carbs for my first time so this oughta be an adventure. At least I found out now and not a few days before my trip in June... I feel bad that's I've ridden it the last few years like this. But we'll get it fix right this time.
            Thanks again
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
              Look on the bright side, maybe you just broke the screw off.
                Ok guys carbs are off... And the lil tip of that bastard is stuck in there good. So I'm taking a break
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                    Wash your filthy hands!!!
                      Ahahaha...Greg beat me too it!
                      Joab
                      "If nothing else, it will be interesting..."
                      ______________________________________________
                      1979 XS1100SF
                      1972 XS2 650
                      Ozark, Alabama
                        to bust to wash....
                        here is what a non broke one looks like
                        Don
                        old:
                        1989 kawi ex500
                        1996 yzf-r6
                        1999 yzf-r1
                        2001 kawi zx-6r
                        2000 Ducati 748
                        2002 YZF-R1
                        • #13
                          Yup, just like the one in my hand.
                          I know a busted one from a good one.
                          • #14
                            and we have an open hole....
                            Man that think was stuck in there!
                            Pin drill to my rescue again. What a PITA to get everything lined up... Had to one eye everything and I haven't even been drinkin yet! I measured the needle and found a pin the same size. popped a center guide into it and to the vise we went. I figure it can't run any worse than it did with no hole
                            I've never seen a mixture screw with such a small end and taper...
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                            • #15
                              Sharp as a sewing needle aren't they?
                              The size of the oraface won't make a big difference because the flow will be adjusted with the screw. It will be different from a stock one though.
                              That's why I cringe when I hear of people counting turns to try and get them all the same. They are all different and have to be adjusted individually.
