So I'm preparing myself for tomorrow nights Carb Sync adventure on "Old Man"
The old dog hasn't ran since my little trip 2 weekends ago. So in prep I decide to pull the plugs and check em all out in my reader, and Yes I am THAT guy
the guy that owns a plug scope... It's one of the few tools that did not leave with the race car, trailer, and tools. anyhow... I wanted to take a look @ them so I can get a better understanding of where I'm to start and what problems He may have. (that and I was looking for a good excuse to hide in the garage
) 1 and 2 are pretty lean since the valve adjust, no detonation freckles tho, probably cuz I run super in it, 3 is kinda dirty, 4 looks like I would expect it to look with the little idle time it had putting it back in the garage.
So @ this point I haven't even finished my first beer so I thought.... hmmm haven't checked the compression in about well EVER
Lets get the Boy warmed up while I finish my beer.
Warmed up, plug wires off. comp gauge out. Now some may run different procedures @ this point, this is how I do it. pull plug, Roll it over with throttle closed and gauge off, to clear out cylinder. attached gauge to cylinder... open throttle to WOT roll motor over till needle stops, without letting go of the throttle clear gauge reading, repeat 2 more times taking mental note of the last 2. The first one don't count as you just compressed some fuel. average the last 2 and record.
This is what I came up with. #1 167psi #2 171psi #3 169psi #4 170psi
So I know the book says 142psi @ sea level.... I'm just gonna assume that's a base line for @ sea level under perfect atmospheric and barometric conditions. I'm pretty certain this thing doesn't have a big bore kit in it. I would have remembered Dad doing something like that. anyways am I right in assuming that 142# is a base line? the high pressure conditions I've got outside right now could cause the extra? I know when we use to put cylinder heads on the flow bench the flow thru a port could change with the rise and fall of the weather, that's why we recorded such things @ time of testing....
Ok that was long winded.... as usual
