found a random plug....
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    so im going through and trying to sort out a wiring gremlin, thats its own problem and i know what and where to check, however, i found this random plug hiding behind the fuse panel, and in the wiring diagram it appears that this is a "terminal Connector", however theres nothing for this to connect to...am i missing something here?
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
    That connected to the 'accessory' fuse sub-panel that sat below and to the rear of the stock fuse panel. That was for hooking up any added electrical items. It's probably still on the fuse panel backplate, if you're not planning on reinstalling that, it's a left-over....
      • 9981
      I just went and looked at my SF and that plug with the black and red wires appears to go to the main power fuse at the bottom left of my stock fuse box.
      • airborneXS
        • Feb 2012
        • 338
        • Houston, TX.
        damnit...thats right...i do remember removing that...my bad....im too young to have this bad of a memory...(although a 155mm howitzer converted into an ied may have caused this....oh well)
        Wolf
        Moto Militia MC
          • 9981
          Then why is there a fuse in the block and it plugs directly into the harness?
            • 9981
            Never mind...........I see.
