tire
  • Nightengale
    • Jun 2011
    • 521
    • Hampton, VA.
    tire
    would the tire size 140/80-17 work on a 81 H??
    xs1100 hartail bobber
    http://i1169.photobucket.com/albums/...-38-36_563.jpg
    Hi Nightengale,
    As you already know the limiting factor is the swingarm space.
    Give the brand too and someone may have already tried it?
    Does the manufacturer give a measurement for the installed tires width? If so check that with a tapemeasure on your bike. Also check the WIDTH of rim required by that tire? does it match your wheel? check the weight rating too you maybe surprised. Compare overal circumference too as that will affect the speedometer. Correction you adjust in your head
      The short answer is no. But....it depends upon the tire manufacturer. If their tire runs narrow, it might fit. 130 wide is the design fitment. That is assuming standards and Specials have the same swingarm.
      • Nightengale
        • Jun 2011
        • 521
        • Hampton, VA.
        exact tire
        Shinko SR777 Wide White Wall Front Motorcycle Tire Size: 140/80-17 it will fit on a 17x 3.50 rim
        • scoot
          • Dec 2007
          • 153
          • Poway, CA: San Diego County
          By the way,the rear wheel size will not have influence on speedometer reading, as the speedo is driven by the front wheel.
          scoot
          • Nightengale
            • Jun 2011
            • 521
            • Hampton, VA.
            scoot
            i was just thinkin that.
              First, note that this is a front tire, and yes it does make a difference; it's a bad idea to run a front on the rear. Plus the 17" rear rim is only 2.5" wide. So if your heart is set on a whitewall, I think about your only choice will be to swap to a 16" rear wheel off a Special (along with the proper spacer and caliper bracket) as you can find a rear whitewall that will fit that rim...
                scoot
                Hi scoot you are of course correct. What was I thinking
                Oh some vague left over memory from when I changed my FRONT tire size
                • Nightengale
                  • Jun 2011
                  • 521
                  • Hampton, VA.
                  thats what i thought, might just try some of the white wall tire paint.
                  • Elevener
                    • 608
                    • small town in TEXAS
                    Just curious here...I run a rear on the front on another motorcycle. Turned around of course. Whats the dif between front on rear?
                    Trapped in time. Surrounded by evil. Low on gas.
                    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
                      The front's usually have less tread depth and a much lower load rating for a given size.
                      Rear to front is OK as long as you reverse the direction; the tire's better than it needs to be.
                      • radical123
                        • Dec 2008
                        • 172
                        • salem or
                        1980 Yamaha XS1100 XS1100LG
                        Been looking for a Dunlop front tire online and I am having Problems with the correct size to order.
                        Anyone know the correct tire to order? And the stock size # for the 1980 Yamaha XS1100LG
                        Thanks
                        1980 midnight xs1100 Rebilt cosmetically
                        1980 midnight xs850 bagger
                        1980 Special xs1100 (all apart)
                        1979 special Special runner
                        2011 street glide
                          Stock front tire is a 100/90-19....
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            Acually the "stock" size would be 3.5-19 wouldn't it be Steve?
                            100/90-19 would be modern metric equivalent... lol sorry I had to
                            When I was shopping tires for my XS I discovered my Dad had been running a rear 3.25-19 Perelli Phantom backwards. I guess that's an old school move. It threw me for a loop, not only tire size but the fact it was on backwards baffled me. The bike shop guy told me that's how they use to do it "back in the day"?
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                            2005 V-Star 1100 Classic
                            • radical123
                              • Dec 2008
                              • 172
                              • salem or
                              Thanks
                              Thank you Steve and Don.
                              2011 street glide
