Originally posted by copracr
View Post
Yes, you need to adjust your valves, although not desperately. All but one are too tight, and that one is at minumum spec. Exhaust clearance should be .008-.010", and you have a choice on the intakes; the 'early' spec of .006-.008", or the late spec of .004-.006". Different schools of thought on the adjustment; run them 'tight' and have a quieter motor (which was the only reason for the change), but less time between adjustments. 'Loose' = longer time, more noise. Either will work, I'm lazy so I run mine loose...
