Carb jets
  • copracr
    • Jul 2008
    • 71
    • Brunswick,OH
    Carb jets
    It's that time of year again, maintenance on the bike.
    I'm rebuilding my carbs because they've been sitting for 2 years with the same gas in them and of course this year it wont hardly run. Prior to this sitting spell the only issue I had was I heard valve ticking noise and a flat spot under 3k. I'm replacing the pilot jets and I was wondering if these sizes sounded right: 42.5 pilots, 132.5 mains. My only mod is a Kerker exhaust, and I'm considering a new K+N style air filter.
    I can usually do a basic R+R of the carbs (about half the time anyways), but I can't do any real tuning or picking jet sizes.
    any thought?
    Oh, and if you can point me to a good place to buy pilot jets that would be super
    1980 XS1100SG Special
    Just drive it all year and you won't have any issues
    If you have the '80-'81 style carbs then those main jets are way to big. Start more in the 120 range.
    • copracr
      • Jul 2008
      • 71
      • Brunswick,OH
      Whoa, really? It ran like a well oiled machine from mid to high range, that seems like a big step
        • 7808
        FWIW, my SG has a stock airbox and 4 into one exhaust. If it matters, there's a K&N filter in the box. It is jetted 110, 120, 120, 110, with 42.5 pilots. It runs great!
        • copracr
          • Jul 2008
          • 71
          • Brunswick,OH
          Is there an obvious way to tell if I have 80-81 style? And if I dont have that style is my jetting more appropriate? Like I said, I'm not real up on carbs but that seems like a big jump to run well.
            Look here..... http://www.xs11.com/forum/showthread.php?t=35964
            • tom clisham
              • Sep 2010
              • 627
              • Northern Illinois
              The quickest & easiest way to tell 80-81 from earlier carbs is by the support brackets.
              78-79 only have the one L bracket joining all 4 carbs & carbs are all joined at top by small hourglass shaped brackets attached to top covers.
              80-81 have the L bracket on the bottom plus a one piece strap joining the carbs at top just above intake openings. No small brackets joining carbs at top covers.
              Tom Clisham
              79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                80-81 Specials run 110's across all four carbs stock. The Standard, Yamaha did the one step bigger for middle two cyl. with 115's/120's. They dropped that as it was a bit anal even tho inner two cyl. run a bit hotter. Difference between the two models was the metering rods, which accounts for the jetting differences. The XJ stock jetting was 112.5 all across. With your exhaust mod I'd go with 112.5's across all four. 42.5 IS also the stock pilot jetting....leave it that way. Use Genuine Mikuni main jets/pilot jets or you WILL have a tuning nightmare.
                  Steves link will help you tell which you have. Even if you do have the early carbs, then your jetting is too lean.
                    • 5057
                    Also, on the later models the idle adjustment knob is on the bottom torards the front, the earlier models have it on the top towards the rear.
                    • copracr
                      • Jul 2008
                      • 71
                      • Brunswick,OH
                      yep, they look like originals. Guess I should start working on this
                      • copracr
                        • Jul 2008
                        • 71
                        • Brunswick,OH
                        Wait, smaller number=smaller hole right?? I'm running a way too big main jet with 132.5's in there. I should start with a 120 maybe?
                        I got Mikuni pilots: http://www.amazon.com/gp/product/B0050AO4Z2
                        They're 42.5's
                        I also ordered a K+N while I was there.
                          '80+ carbs had 110-120 main jets stock. '78-'79 had 137.5 stock. Becayse of the design differences you need to stay in that range. So if you are sure you have the later carbs then I would probably start at 115 and tune from there, may need to go higher but you won't know till you run it some.
                            I would start with the 120s.
                            • killercummins
                              • Mar 2012
                              • 19
                              • Owenton, KY
                              Im running 120 main 45 pilots with pods and kerker 4to1. Plugs look good. Its needs some more fine tuning. Now my clutch is unhappy.
                              95 Dodge 2500 RCLB 2wd 5spd cummins 303k miles. Alot of go fast parts and smoke.
                              80 xs1100sg 16k miles. Kerker 4 to1 Pods with stock airbox tubes. 120 mains 45 pilots slipping clutch
                              86 Samurai soft top 16v tracker motor, 6.5 to 1 t-case gears 34" tractor tires among other stuff
                              Horsepower is how fast you hit the wall, Torque is how far you take the wall with you.
