going now to try...
well i was left stranded again...
79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
09 YZF-R1 " Toothless"
04 Buell XB12R "Butterfly"
"I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
Wolf
Moto Militia MC -
Nothing...its getting fuller I can smell a ton coming from the exhaust...79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Moto Militia MCComment
It was worth a try.
Man, I just want to haul @ss down there and see what's goin' on. This remote control bike repair wears me out....
So, it was running on 2 & 3 before you checked the pickups and now it won't start at all. Right?Greg
The list changes.Comment
I got it to run on all 4, before I started unplugging and ohming the coils pickup coils and everything else...started trying to plug **** up and test it...just ohm's the coils again, im gonna test it a second time but primarys are 1.8 secondary Im getting nothing....uh!79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Have you checked out those new (to you) coils?Greg
Tested it a second time...1.8 from both primaries, but secondaries with and with out plug caps, nothing....is there anything on the bike that could cause this? The numbers were good the other day...I haven't changed or fired the bike up since then other than mess with the cables...with the plug caps off I get in spec numbers for the 2 n 4 coil, however put the plug caps on and it jumps up to 130 ish....ugh...my new coils appear to ohm in spec so im gonna change those and see what happens...79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Tested it a second time...1.8 from both primaries, but secondaries with and with out plug caps, nothing....is there anything on the bike that could cause this? The numbers were good the other day...I haven't changed or fired the bike up since then other than mess with the cables...with the plug caps off I get in spec numbers for the 2 n 4 coil, however put the plug caps on and it jumps up to 130 ish....ugh...my new coils appear to ohm in spec so im gonna change those and see what happens...Greg
Yea my bad I just explained it backwards...got them out now gonna re ohm them and ohm the new set...standby...btw...thank u so much for taking ur time out of ur day to help me with this...all I have is this scoot atm...gotta completely rebuild the r1 after a nasty crash last winter, and the buell decided it didnt want to have a spark plug in it anymore...the head stripped it out and shot it out of the motor...gotta drop the motor and helicoil the head....79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
No prob. Glad to help as much as I can.
Just get frustrated sometimes trying to do repairs with a mouse rather than a wrench.Greg
What grounds the coils? The bolts that run through (allthread is what I have) that secure the coils in place, is that the grounding for it?79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Got the new coils in place, plugged up, but not bolted in place...nothing happens...79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Have you got power to the 2 red/white wires going to the coils when the ignition switch is on?Greg
The coils circuits are grounded through the wiring, the bodies don't require ground.Greg
Not sure...how do I check it?79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
I know you have a VOM, you got a test light? Either will work. Ground one lead and stick the other in the 3 way connector.Greg
